Author Topic: Led Viewing Angle?  (Read 1685 times)
Brian74
  • Yep... I built that!!
Led Viewing Angle?
« on: April 28, 2013, 08:43:48 pm »
Im looking to get some leds for my buttons for my second cab. I have been looking at 5mm 12v leds, whats the best viewing angle to get??
Brian74
Re: Led Viewing Angle?
« Reply #1 on: April 29, 2013, 09:07:55 pm »
Jumpman64
  • Last login:October 12, 2017, 04:58:42 pm
« Reply #2 on: April 29, 2013, 10:21:50 pm »
Not sure which ones you're comparing but I would suggest that wider is generally better in the sense that it will provide a more uniform distribution, with less or no "hot spot" compared to a more narrow cone.
Brian74
« Reply #3 on: April 29, 2013, 10:23:35 pm »
Yeah, I was comparing round and flat top leds.
Sent from my SGH-T989 using Tapatalk 2
lilshawn
  • Last login:June 16, 2026, 07:23:28 pm
« Reply #4 on: April 29, 2013, 10:29:16 pm »
flat will be wider angle.
Brian74
« Reply #5 on: April 29, 2013, 10:32:13 pm »
Thanks for the replies guys. Have the leftover il translucent centers from my other cab. Thought I would throw some single color leds in them.
  • Last login:Today at 03:02:04 am
« Reply #6 on: April 29, 2013, 10:48:49 pm »
To determine the correct LED to use, measure the width of the button surface you want illuminated and the distance (button depresed) to the top of the LED.
Draw the viewing angle of the LED, mark the distance on both legs, and measure the distance between marks.
If the distance between marks is shorter than the illuminated surface diameter, it will cause a "hot spot".
Brian74
« Reply #7 on: April 29, 2013, 10:53:57 pm »
Scott my friend, you are full of useful knowledge!!! Thanks for the help! :D
matsadona
« Reply #8 on: April 30, 2013, 04:59:13 am »
The so called "straw hat" LED's have a wider angle, and might be better suited for this.
lilshawn
« Reply #9 on: April 30, 2013, 10:27:49 am »
ive also carefully filed the tops flat on standard led's to make them wider angle.
