Author Topic: Tron and the minigrip joystick = BLARGH  (Read 2312 times)
happyfunball
  • Last login:December 11, 2015, 07:49:39 pm
« on: April 27, 2013, 09:10:44 pm »
so i redid a control panel with the spinner, 3 buttons and a trigger joystick. after some teething getting the minipac all worked out (all operator error or tweaks) i settled in to play some tron.
granted, I have not played an actual tron since probably 2004 but this joystick doesn't feel right at all for it. alfter using it I was wondering if the tron joystick was a 4 way cause it just felt wrong.
but I looked it up and it isn't, so it must be this joystick. maybe it doesn't feel as tight as I remember? plus i'm growing to really dislike microswitch joysticks.
my intention was to eventually remove the shaft and replace it with the tron reproduction joystick I got from groovygamegear, but after using this stick I think a better alternative needs to be found unless a miracle happens and an actual Tron cab falls into my lap.
anyone have a suggestion for an alternative joystick?
  • Last login:Yesterday at 10:08:14 pm
Re: Tron and the minigrip joystick = BLARGH
« Reply #1 on: April 27, 2013, 09:35:02 pm »
The TRON joystick was an 8-way, but it used a special restrictor plate that made hitting the diagonals harder -- Encryptor was selling repros here but he's out as of late Dec 2012.
For a better joystick idea, look at Le Chuck's Darkade and his related thread on TRON in-game autoswitching.
Now that autoswitching sticks are becoming more common, you should have a variety of sticks to choose from.
« Last Edit: April 27, 2013, 09:37:53 pm by PL1 »
happyfunball
« Reply #2 on: April 27, 2013, 09:36:39 pm »
that could be it. just seemed like an 8 way would be a PITA for the tank and lightcycle portions, and it is, frankly.
I'll check into those links, thanks.
Jumpman64
  • Last login:October 12, 2017, 04:58:42 pm
« Reply #3 on: April 27, 2013, 11:40:04 pm »
I use it for spiders, cone, & tanks, and use a regular restricted 4-way for light cycles.  It's a decent compromise, but it does suck when you forget to switch to the other stick.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: April 28, 2013, 07:22:16 pm »
I don't forget, and I use my U360 for cycles, but the game overall isn't good enough to care that much.
-Banned-
