Author Topic: AdvanceMenu  (Read 5897 times)
mattr69
  • Last login:May 01, 2020, 05:24:01 pm
AdvanceMenu
« on: April 25, 2013, 03:46:02 am »
Hi,
Does GroovyMame use AdvanceMenu or AdvMenu+? I'm confused. :-) I'm having trouble configuring types/favorites etc and documentation is... woeful.
Cheers,
Matt
Gray_Area
  • -Banned-
  • -Banned-
Re: AdvanceMenu
« Reply #1 on: April 28, 2013, 06:19:34 pm »
AdvMenu+ ?
-Banned-
Rockman
  • Last login:January 30, 2014, 12:10:33 pm
Re: AdvanceMenu
« Reply #2 on: April 29, 2013, 06:04:34 pm »
Hi guys!
GroovyArcade uses a modified version of AdvanceMenu called "AdvmenuPlus".
Here you can see the improvements over the original version in this link. (Sorry, is from ArcadeForever Spanish forum, but is the only documentation available to date).
http://arcadeforever.forumfree.it/?t=42527183&st=525#entry533165578
This special version included in GA, adds new options in the *.rc configuration file, to create lists of favorite games, create layouts for each emulator and a lot more.
Regards.
Calamity
  • Moderator
  • Last login:June 16, 2026, 03:08:29 pm
  • Quote me with care
Re: AdvanceMenu
« Reply #3 on: April 30, 2013, 04:10:48 pm »
Hi Rockman, thanks a lot for the documentation, I'll be translating it as soon as possible.
Steps to create a log:
Rockman
Re: AdvanceMenu
« Reply #4 on: April 30, 2013, 06:04:34 pm »
Thanks for your SUPERLATIVE GroovyMame. :)
Calamity
  • Moderator
Re: AdvanceMenu
« Reply #5 on: May 01, 2013, 01:57:16 pm »
Just added the documentation to the GA wiki:
https://code.google.com/p/groovyarcade/wiki/AdvmenuPLUS_reference
Gray_Area
  • -Banned-
  • -Banned-
Re: AdvanceMenu
« Reply #6 on: May 01, 2013, 06:39:50 pm »
When, and why, did this get bundled with GM?
-Banned-
wesbrown18
  • Last login:October 24, 2018, 09:29:23 pm
Re: AdvanceMenu
« Reply #7 on: May 01, 2013, 08:12:12 pm »
GroovyArcade, not GroovyMame.
GroovyMame is the emulator.  GroovyArcade is the Linux distribution including GroovyMame and AdvanceMenuPlus.
Rockman
Re: AdvanceMenu
« Reply #8 on: May 02, 2013, 08:42:50 am »
Great work Calamity! :)
Gray_Area
  • -Banned-
  • -Banned-
Re: AdvanceMenu
« Reply #9 on: May 04, 2013, 10:55:21 pm »
Ohhhhh. Riight. Well, why was AdvMENU picked for that? Just curious.....
-Banned-
wesbrown18
Re: AdvanceMenu
« Reply #10 on: May 04, 2013, 11:18:45 pm »
Well, several things --
* The selection of good frontends for Linux is more limited.
* AdvMENUPlus has support for 15khz monitors built into it.
* AdvMENUPlus also has support inbuilt for the various emulators that are included in GroovyArcade.
* AdvMENUPlus generates ROMlists with a minimum of intervention -- i.e. none -- which is important for a distribution that can be booted or played from LiveCD in addition to from a hard disk.  For example, Cabrio is a much slicker front end, but generating ROMlists for it is nontrivial.
Calamity
  • Moderator
Re: AdvanceMenu
« Reply #11 on: May 05, 2013, 10:55:51 am »
Mmmmm.... may I ask... WHY NOT?
AdvMENU is simple and does the job. I *think* I suggested it to Chris at the time he was building the first versions of the live-cd, he was using WahCade and had some issues configuring it.
