Author Topic: RGB- Blue will not change value on screen?  (Read 1435 times)
Fallen_Veteran
  • Last login:February 06, 2014, 10:06:38 pm
« on: April 22, 2013, 09:21:29 pm »
When I adjust the Red and Green there is significant changes to the monitor, the Blue however, nothing?
Is this a capacitor issue or?
(Never worked on a monitor before and don't want to electrocute myself!)
grantspain
Re: RGB- Blue will not change value on screen?
« Reply #1 on: April 23, 2013, 02:11:01 pm »
do you have any blue on the screen at all,if so then track is broken to pot
Fallen_Veteran
« Reply #2 on: April 23, 2013, 03:39:07 pm »
Not that I can tell. On the test screen the blue appears to be black and I cannot get anything close to purple to show up.
grantspain
« Reply #3 on: April 23, 2013, 05:14:21 pm »
ah right ok then inspect your neck card for broken tracks
whats the make/model of the monitor?
Fallen_Veteran
« Reply #4 on: April 23, 2013, 07:42:50 pm »
Where do I find the Model/Make info on the monitor?
grantspain
« Reply #5 on: April 24, 2013, 06:37:57 pm »
its a wells gardner k7000 series
ed12
« Reply #6 on: April 24, 2013, 07:42:18 pm »
from a second look at his pic's
i could not see a crack,but i can see a wack of cold solder joint's
thr green transistor is of big interset to me >the 1 in the middle of the 3<
they look cold enough,i would fire up a soldering iron
and :reflow:...
ed
