Author Topic: PPSSP: New version is out! Ridge Racer PSP on the big screen!  (Read 9204 times)
isamu
  • Last login:February 19, 2026, 01:09:24 pm
A new version of PPSSPP emu is out. This is THE best PSP emulator in the world at the moment. Now, Ridge Racers 2 PSP, a game I have invested over 500 hrs in while on the road or waiting in line at the grocery store, is emulated VERY well and suffers only from some minor graphical issues. Good thing is it works with both Xbox 360 controllers and Keyboard keys SIMULTANEOUSLY!!! This means I can use my ECCI wheel via x360ce custom app, and then use my shifter and pedals via xpadder or Joy2Key! TOTALLY TUBULER!!!!!!!!!!!!!!  :dizzy:
Check out the thread...
http://forums.ppsspp.org/showthread.php?tid=2865
SegaOutrun
  • Last login:March 28, 2019, 03:02:05 am
  • Brakes are overrated
Re: PPSSP: New version is out! Ridge Racer PSP on the big screen!
« Reply #1 on: April 22, 2013, 08:47:20 pm »
Initial D works as well =)
isamu
« Reply #2 on: April 23, 2013, 02:42:12 pm »
Nice :)
SPANKIN' new version is out peeps!
http://www.ppsspp.org/
RR 2 on the big screen  :notworthy: :dizzy:
isamu
« Reply #3 on: May 11, 2013, 08:06:21 am »
Gentlemen, I bestow upon you a nice delicacy of screenshots from my RR session just now:
A sight for sore eyes......
To be able to play these classic Rage Racer and R4 Type 4 tracks....at 60ps...on the big screen.....with updated graphics.....and a steering wheel/pedals/shifter....
*sigh*....Truly a dream come true.
Thank you Namco for this game. Thank you Henrik for making this SUPERB emulator!!!!!!!!!!!!!!!!!!!
Truly one of the few times you'll hear me say "It's a thing of beauty!"
  • Moderator
« Reply #4 on: May 11, 2013, 08:58:24 am »
Man, I'm tired of having to work on projects instead of playing them.
I can't wait to test this out.
SegaOutrun
« Reply #5 on: May 11, 2013, 03:00:10 pm »
How are you using your steering wheel with ppsspp? I was playing intial d the other day and gave up trying to find the right settings. way too sensitive
isamu
« Reply #6 on: May 11, 2013, 07:18:34 pm »
what kind of wheel do you have bro? I'm guessing a 900 degree wheel like the Logitech G25/G27? Anyway the reason it appeared too sensitive is because ppsspp probably thinks the wheel is a digital input device. Or maybe the settings in your drivers are where it's too sensitive. What I'm doing is using a virtual joystick through an app call ppjoy. Then I proceed to tweak and calibrate the analog steering input through ppjoy's calibration menu. On my 9000 degree ECCI 7000 wheel, I turn the wheel about JUST *SLIGHTLY* PAST 90 degrees in each direction, then calibrate the gas and brake pedals. PPSSPP will see ppjoy as your 1st joystick, and you will then be able to steer the cars the way you want. Keep tweaking the analog steering in ppjoy til you get the results you want. You make it as sensitive or non-sensitive as you want. Hope that helps :)
MartinJames
  • Last login:March 28, 2021, 10:10:33 am
« Reply #7 on: May 12, 2013, 08:11:58 am »
I cant get any Ridge Racer roms to work, just a black screen. What am I doing wrong?
isamu
« Reply #8 on: May 12, 2013, 10:07:17 pm »
Hm not sure bro. You sure you have the emulator pointed at the right roms directory?
« Reply #9 on: May 13, 2013, 08:08:47 am »
its more of an ISO / CSO than a rom....
