Author Topic: RCA Television - F26051EM - Issues  (Read 2089 times)
Seith
« on: April 22, 2013, 12:58:05 pm »
Hello,
I have an RCA television that is giving me issues, wondering what needs to be done to fix it.  Let me start from the beginning.
I installed it in my cab a few months ago and got to firing it up about a month ago, only to find that it didn't want to power on.  I had it plugged into the smart strip I installed in my cab so that it would turn on when the PC powered on.  Everything else that was supposed to turn on did, except the television.
So then I plugged it into one of the "always on" ports on the smart strip, left it to sit there in the "off" position directly hooked to power for about 25-30 minutes, then came back to it, powered it on separately from the rest of the cab, and once the power light came on, powered the PC on.  Bingo, got a nice picture up on the screen.
This worked fine for weeks, I just left the TV always-on in the hot plug of the smart strip, and all other cab components (marquee light, speaker system) would switch on via the PC switching on.
The other day, I power the cab on (remember, the TV has been on for about a month at this point), and start to play.  Well, about 40 minutes in, I notice the screen start to get slightly darker, and stay that way for about 3 seconds, before switching off completely.  It was like a gradual loss of picture over the course of about 5 seconds.  I go around to the back of the cab to see what the power light is doing on the TV and it's blinking on-off, on-off, on-off, ad infinitum.  I press the power button on the TV, let it sit again in the off position plugged into a hot socket on the smart strip, and come back to it about 10 minutes later.  Power it on, it comes on without any issue, and works for about 5 minutes, then fades and reverts back to the off-on routine it was doing before.
What do I need to do/buy to get this display fixed?  I called my local TV repair shop and not only did they want 35$ to just look at it, but I had to bring it to them (not exactly easy when it's decased and mounted in a cab), and he said it would be about 60-150$ to repair depending on the issue.  This TV was free, and i'm not averse to hitting the garage sales for another 27" television as long as the mounting clips are in the same position as the one i've got currently.
What does it sound like needs replacing on the television based on what I described happening?
Gray_Area
  • -Banned-
  • -Banned-
Re: RCA Television - F26051EM - Issues
« Reply #1 on: April 25, 2013, 01:32:32 am »
Unless you can find schematics for it....and you really want to go that route.....I suggest replacing it.
-Banned-
Seith
« Reply #2 on: April 25, 2013, 08:32:39 am »
Yeah, that seems to be the general consensus.
Here's a different question then, perhaps for someone that has seen a lot of decased CRTs - if a television is a 27", does that mean that the mounting clips on the edges of the tube are in the same spot relative to one another?  I took measurements of where my bolts go in last night in preparation of replacing the television, and I got height and width - now obviously I won't be able to just go up to someone looking to sell a TV and ask them to take the casing off for me, so I guess I just have to take my chances?
I guess the question is:  is there a standard?
sandheaver
« Reply #3 on: April 25, 2013, 09:50:20 am »
seems like it could be fixed to me.
retouching solder joints and replacing capacitors fixes a lot of weird issues.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: April 26, 2013, 02:50:01 pm »
If you mounted via the eye hooks at the outside corners of the tube itself, yes, I think. Even if it ain't, just do it. STILL a lot less work.
Go get it, love.
-Banned-
Seith
« Reply #5 on: April 29, 2013, 07:36:19 am »
Thanks!  Hoping to find something this weekend!
