Author Topic: Need help getting multiple spinners to work please  (Read 1477 times)
Reopen
  • Last login:November 13, 2013, 12:56:08 am
« on: April 14, 2013, 11:09:48 am »
Hello
    I have more than 4 spinners plugged in.  All work but they all register as the same controller. How can I fix this? The are each connected by their own USB input.  Thanks for the help.
  • Last login:Today at 12:39:11 pm
Re: Need help getting multiple spinners to work please
« Reply #1 on: April 14, 2013, 11:27:43 am »
What brand of spinners? TT2, Spintrak, etc.
What axis are the spinners wired to?
Is multi-mouse enabled in mame.ini?
« Last Edit: April 14, 2013, 11:30:21 am by PL1 »
Reopen
« Reply #2 on: April 14, 2013, 01:43:54 pm »
They are slikstick model from happ.  I am not sure about he axis or the mouse settings.  How can I find out?  Thanks so much
« Reply #3 on: April 15, 2013, 12:28:28 am »
On that spinner, there is a jumper on on the encoding board that allows you to switch from X-axis to Y-axis. (Optional)
For suggestions on how to configure for multi-mouse, that depends on which flavor of MAME you're running. (basic command line MAME, MAME32, MAMEUIFX . . .)
The Graphic User Interface (GUI) versions usually have a checkbox in one of the configuration menu windows.
For non-GUI versions, you can open the mame.ini file and change multi-mouse from "0" to "1", save, and exit.
After that, map the desired spinner to the desired player default in MAME and you'll be playing Warlords in no time.   :cheers:
Reopen
« Reply #4 on: April 16, 2013, 04:14:34 pm »
Thanks so much.  Problems solved.  Thanks again
