Author Topic: Removing Old Contact Cement! - The Easy way!!!  (Read 3731 times)
silar
  • Last login:May 06, 2013, 10:13:19 pm
  • Nerd with a project! WOOT!
« on: April 06, 2013, 03:00:37 pm »
I've been working on my cab trying to remove the old contact cement on the sides where someone had laminated them with Formica.  I've tried goof off, acetone, and mineral spirits as far as chemicals and a heat gun and scraper.  The heat gun and scraper method worked better but it was a slow and tedious process...
Well, I do believe I've finally found the easiest and fastest way to remove the cement!  This is not for anyone that wants to try to preserve the original finish so you've been warned!
Take a heat gun, hold it about 1/2" to 1" above the contact cement and slowly move it along making sure the cement starts to bubble and brown as shown in the pic.  Let it cool a bit, and then come back with a fine wire brush in your drill (shown in the second pic) and go over it.  It comes right off!!!  So much easier than wearing yourself out trying to scrap that junk off.  The wire brush doesn't damage the plywood.
Also less of a smell than using chemicals!   :applaud:
silar
Re: Removing Old Contact Cement! - The Easy way!!!
« Reply #1 on: April 06, 2013, 03:23:22 pm »
And here is after...  Like I said, not for anyone who is trying to preserve the finish underneath...
yaksplat
    • Random Projects
« Reply #2 on: April 08, 2013, 11:21:42 am »
Freezing it may work as well.
http://yaksplat.wordpress.com
silar
« Reply #3 on: April 08, 2013, 11:30:51 am »
Most people can get or already have a heat gun..  A bit harder to find a CO2 extingusher...  Or a Freeze gun..   :lol
yaksplat
    • Random Projects
« Reply #4 on: April 08, 2013, 11:47:25 am »
Cans of the keyboard cleaner propellant stuff.  Hold it upside down.  That's the common method for removing mylar from pinball playfields.
silar
« Reply #5 on: April 08, 2013, 07:24:26 pm »
Good point, but I'd say that would start getting expensive if you had a lot of contact cement to remove.
