Author Topic: Robotron 2084 Convert to Mame/Multi  (Read 4742 times)
silar
  • Last login:May 06, 2013, 10:13:19 pm
  • Nerd with a project! WOOT!
« on: April 05, 2013, 04:58:43 pm »
I've been wanting to do this since Mame came out around 1997, so roughly 16 years later, I finally picked up my empty cab.  It's a 1982 dated Robotron 2084.  came with the sides laminated in a red color formica.  Also came with the original Coin Mech Inc. coin door and mechanism, and front smoked glass.  It diid not have any control panel attached, so I was going to have to build my own.
I opted to remove the laminate since it made the sides a bit thicker and sticks out just past the existing T-molding.
Here is a drawing I made to scale in sketchup of the cab and what I am doing for a control panel.
I'll post more pics later when I get them off my phone...
silar
Re: Robotron 2084 Convert to Mame/Multi
« Reply #1 on: April 05, 2013, 06:00:25 pm »
Here is what the cab looked like when I got it.
silar
« Reply #2 on: April 05, 2013, 06:02:20 pm »
I took the security bars off and filled the holes, sanded and repainted blue.  I also cleaned up the coin door and mech and made my own inserts for the reject buttons....
silar
« Reply #3 on: April 05, 2013, 06:09:12 pm »
Here's what the cab sides look like without the laminate.  I pulled it off and have a lot of hardened contact cement to deal with, but am slowly working on it....  BTW, from what I have found...  a heat gun and scraper work better than using any chemicals, and leaves less of a mess..   ;)
« Last Edit: April 05, 2013, 06:16:26 pm by silar »
silar
« Reply #4 on: April 05, 2013, 06:21:22 pm »
Here's the control panel based on my sketchup drawing.  T-molding slots are already cut.  I went for a fighter type layout with buttons on the sides for pinball also.  The top is removable and I'll house the keyboard and mouse in there...  This is right after I assembed the control panel base and filled the screw holes and a few dings...
silar
« Reply #5 on: April 05, 2013, 06:23:21 pm »
Starting to paint the base and panel...  Not in the house.  I just brought it in once the paint had dried a bit...  It was starting to get a bit cool out there...
silar
« Reply #6 on: April 05, 2013, 06:28:50 pm »
Here's the panel.  I opted for the XIN-MO interface.  I should have filled the grain on the plywood, but oh well, It'll give me a chance to redesign the panel later to add a trackball.
As you can see, I tried to go as cheap as possible.  Zippyy ball top joysticks and Arcade Prime buttons.  All from Groovygamegear.com  I plugged it into my system temporarily and tested it, and everything works great.  I actually like those buttons!
silar
« Reply #7 on: April 05, 2013, 06:30:35 pm »
I got the T-Molding in today from gamemolding.com, a board member here.  It is exactly the yellow I was hoping for.  Matched my yellow buttons nicely..  I'll definitely order from him again!
silar
« Reply #8 on: April 05, 2013, 06:35:54 pm »
Here's the light for the marquee.  It's a 13" under cabinet fluorescent from Walmart for about $10.  Kinda hard to make out in the pic...
silar
« Reply #9 on: April 05, 2013, 06:38:39 pm »
Here's the speakers and amp.  I actually lucked into these from a friend at work.  He is a huge car audiophile.  The amp is quite a bit bigger than I want, but I got it all for free so I really can't complain.  Eventually I'll make this also into a Jukebox and add a sub...
Making a new speaker panel which I'll paint black.  The grills will be painted the same blue and the speakers are red, so it'll all somewhat match the whole cabinet color scheme..
« Last Edit: April 05, 2013, 06:52:06 pm by silar »
silar
« Reply #10 on: April 06, 2013, 11:36:52 am »
Here's the control panel just about done.  Still working on the sides of the cab...
The blue tape is where I'll need to trim the t-molding for the edge of the cabinet..
silar
« Reply #11 on: April 07, 2013, 05:49:30 pm »
No input?  Suggestions?
Dance Commander
  • Last login:March 17, 2017, 09:39:30 am
  • Deify Dada
« Reply #12 on: April 07, 2013, 06:41:40 pm »
I like the bright colors, makes it look like a toy box. Are the blue buttons as camouflaged as they look in the pics? They look nearly the same color as the cp.
silar
« Reply #13 on: April 07, 2013, 09:49:25 pm »
They kinda are.  After I put the buttons in, I'm starting to think about changing them to red.  I have a few spares..
silar
« Reply #14 on: April 09, 2013, 04:49:47 pm »
Got some more work done.  Got the sides sanded down and have been gluing/patching the bottom edge since someone apparently drug it around and some of the plywood separated.  Also got the speakers mounted and some other misc stuff...
