Author Topic: Mini Pac or iPac2?  (Read 2145 times)
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
Mini Pac or iPac2?
« on: April 04, 2013, 02:31:16 pm »
I was all set to use the iPac2, now not so sure I shouldn't go with the mini Pac, what's your opinions?
  • Last login:Today at 04:03:53 am
Re: Mini Pac or iPac2?
« Reply #1 on: April 04, 2013, 02:38:56 pm »
If you provide a little more detail about your build, desired controls and your skill level in crimping/wiring, it will be easier for us to provide informed opinions.
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #2 on: April 04, 2013, 02:48:15 pm »
I`m using a minipac, have two joysticks and 6 buttons to each, P1 P2 buttons, side pinball type buttons, a credit button and an exit to game menu button and got about 3 spares (can reconfigure the extra credit buttons etc if needed) used a Ps/2 trackball so not needed with the minipac, if that helps, not sure what your plan is as pl1 says more info would be helpful, bit like asking what car to buy when you go to the shops.
Hit something hard enough it should work, if it dont the result can always be called art :)
DHTech
  • Arcade Flashback
« Reply #3 on: April 05, 2013, 02:54:33 am »
The initial CP will be 2 joysticks and 6 Buttons each side, but I may want to add a trackball or spinner at a later date! crimping cables isn't an issue for me :) is there another alternative interface I should also consider?
« Reply #4 on: April 05, 2013, 04:47:52 am »
Since you are comfortable with crimping QDs and aren't sure if you will want to add a trackball or spinner later, the IPac is probably a better choice than a Mini-Pac at this time.
DHTech
  • Arcade Flashback
« Reply #5 on: April 05, 2013, 10:37:58 am »
Thanks for the input, I think I'll stick with the iPac2, I assume you can add a trackball spinner to that with and OptiPac!
« Reply #6 on: April 05, 2013, 07:33:21 pm »
True.
You can add an optical encoder like the OptiPac from Ultimarc, the OptiWiz from GGG, or there are several other options since some trackballs come with USB or PS/2 encoders.
