Author Topic: Question Regarding Wiring Groovygamegear Trackball  (Read 1378 times)
Yourname942
  • Last login:October 01, 2016, 08:10:20 pm
« on: March 30, 2013, 04:58:29 pm »
Does anyone know how to wire the groovygamegear trackball? I can't find any tutorials/guides online. I'm confused bc the wires aren't loose. (The ends of the wires have connectors attached to them, and some wires are bunched together to the same connector)
Edit:
here is a picture of the trackball:
http://groovygamegear.com/webstore/images/large/GroovyTB_LRG.jpg
« Last Edit: March 30, 2013, 05:02:07 pm by Yourname942 »
  • Last login:Today at 03:37:33 pm
Re: Question Regarding Wiring Groovygamegear Trackball
« Reply #1 on: March 30, 2013, 06:19:10 pm »
What are you connecting it to?
If you're connecting to an opti-wiz no-solder, it should be plug and play.
Red/black is 5v/ground. (right side of board)
Green/yellow is one axis. (Y-axis IIRC probably connects to pins C+D of opti-wiz, assuming the wires come off the lower right corner of the TB)
Blue/purple is the other axis. (X-axis IIRC probably connects to pins A+B of opti-wiz)
You won't damage anything if green, yellow, blue, or purple are accidently swapped around.
If you move the trackball horizontally and the cursor moves vertically, swap green/yellow for blue/purple.
If an axis moves the opposite direction you expect it to, swap green + yellow or blue + purple.
Yourname942
« Reply #2 on: March 30, 2013, 06:35:40 pm »
I'm using an Opti- Pac.
« Last Edit: March 30, 2013, 06:37:59 pm by Yourname942 »
« Reply #3 on: March 30, 2013, 06:46:42 pm »
Installation directions are here.
