Author Topic: Question Regarding Ipac 4  (Read 1722 times)
Yourname942
  • Last login:October 01, 2016, 08:10:20 pm
« on: March 23, 2013, 03:38:31 pm »
I need serious help, Idk why the player 3 and player 2 joysticks are configured as the same buttons:
up down left and right arrows . In WinIpac when I set them up for some reason it thinks that they are the same buttons.. Is there anything I can do so that I can play 4 player games without problems? Thanks.
Edit: For some reason when I try to program the joysticks it keeps setting player 1 and player 3 as up down left and right arrows.
Does anyone know how to fix this?
« Last Edit: March 23, 2013, 04:09:35 pm by Yourname942 »
Yourname942
Re: Question Regarding Ipac 4
« Reply #1 on: March 23, 2013, 04:12:04 pm »
Also the player 3 and player 4 buttons don't look activated in winipac unless it is the same as player 1 and 2...
  • Last login:Yesterday at 06:21:17 pm
« Reply #2 on: March 23, 2013, 04:25:55 pm »
Do you have the correct board selected under WinIPAC's Tools - Options menu?
Yourname942
« Reply #3 on: March 23, 2013, 05:05:38 pm »
what do you mean?
There was an ipac2 and ipac 4 option. I clicked ipac4.
« Reply #4 on: March 23, 2013, 05:59:42 pm »
OK, that's what I wanted to confirm.
Thought you might have selected the wrong board type since that might also cause the other problem.   :dunno
With WinIPAC in Tools - Test Mode, does it see your button presses?
Yourname942
« Reply #5 on: March 23, 2013, 06:08:13 pm »
where are Tools and test mode again? -.-
Yourname942
« Reply #6 on: March 23, 2013, 06:16:43 pm »
when i try to configure player 3's joystick it sets up as up arrow down as down arrow, left as left, and right as right.
the only problem is player 1 does the same.. so idk what to do. (bc as it is right now, player 1+3 have the same joystick inputs, and player 2+3 share the same inputs)
« Reply #7 on: March 23, 2013, 06:21:40 pm »
Launch WinIPAC - Pull-down-menus at top, click on "Tools", then on the top option "Test Mode".
EDIT: I'm running an earlier version of WinIPAC.  See below.
« Last Edit: March 23, 2013, 07:00:49 pm by PL1 »
Yourname942
« Reply #8 on: March 23, 2013, 06:25:25 pm »
I don't see that..
This is what winipac looks to me:
http://www.ultimarc.com/images/wip_main.jpg
the version i have is 1.0.16 winipac. (also players 3+4 are not greyed out like in the above picture.
« Reply #9 on: March 23, 2013, 06:37:07 pm »
BINGO!!
That's the "legacy" version for pre-2004 IPac's.
I assume yours isn't that old.
Try downloading the newer version of WinIPAC here.
« Reply #10 on: March 23, 2013, 06:48:45 pm »
Also, test mode is now one of the icons in the upper right.
I'm running WinIPAC v 1.2.157 which still had the menus at the top instead of the icons that the current screencap shows.
You'll still probably need to de-conflict P2 Buttons 5-8 and P3 joystick directions and possibly a few others.
See here for a list of the IPAC default keys.
« Last Edit: March 23, 2013, 06:55:39 pm by PL1 »
