Author Topic: Stupid Display Settings Bubble  (Read 1566 times)
Cameronj
  • Last login:August 03, 2012, 12:59:01 pm
  • I'm a Super llama!
« on: November 08, 2003, 11:32:06 am »
I am running windows XP pro on my machine and I have the resolution at 640x480 to match my princeton arcadia monitor. To get 640x480 I had to go into the display adapter to select the lower resolution. Now every time the machine boots, a Display Settings bubble pops up over by the clock that prompts me to change the resolution to a higher level. Is there any way to supress this?
Thanks,
Cameron
Cameronj
Re:Stupid Display Settings Bubble
« Reply #1 on: November 09, 2003, 06:35:41 pm »
Does this happen for you guys too?
BillyJack
  • Last login:August 17, 2025, 02:58:00 pm
  • Must...paint...cab...! Must...buy...marquee..!
« Reply #2 on: November 09, 2003, 06:58:17 pm »
If you use TweakUI, there's a part you can uncheck called "Enable Balloon Tips".  That should do it.
BillyJack
Now I've had my head in an elephant, a hippo, and a giant sloth.
-Homer
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #3 on: November 09, 2003, 11:22:27 pm »
All Your Base Are Belong To Us!
Cisco Kid
« Reply #4 on: November 10, 2003, 12:01:10 am »
here ya go :
http://www.winguides.com/registry/display.php/997/
just follow directions and disable the Balloon tips by hand in your registry.  No point in downloading and installing something when it can easily be turned off with just a little effort on your part. (beats downloading a .vbs that maybe a trojan, worm, or some other virus  ;D )
« Last Edit: November 10, 2003, 12:01:57 am by Cisco Kid »
Spaced Invader
« Reply #5 on: November 10, 2003, 12:21:27 am »
I saw that too...this was just easier. And NOT a trojan/virus/or other crawly thing (I always open scripts with notepad and read the code first...wouldn't have recomended it otherwise).  ;)
