Author Topic: FS:Cadillacs and Dinosaurs Cased, Working, Batteries Removed, Orig Capcom Board  (Read 3357 times)
tta583
  • Last login:April 10, 2013, 11:06:34 pm
I have a cased Capcom Cadillacs and Dinosaurs. Both suicide batteries have been removed using the method and ROMs from the Dead Battery Society page.
http://www.arcadecollecting.com/dead/dead.html
After battery removal I have let it run a couple of times, at an hour or two per time, on my bench or in a JAMMA cab with no issues. It was running mono audio via the JAMMA harness.
I have switched it to Q-Sound and ran the RCA outputs to a receiver to test them.  I let it run in attract for about 30min with no issues.
I have coined it, started a two player game, and verified both players respond to all 4 joystick directions and both buttons.
I have not extensively played it as I don't have a horizontal JAMMA cab.
I can run it through self test in the test menu and everything comes back clean.
The pictures show the case cover still off. I will put it back together before I ship it out.
The "in play" pictures are on my 13" bench monitor. The camera does not do it justice, it looks great in person.
$550 shipped in the US.
I don't make it this way often so my ID is probably not known by many, if any, here.  I mainly travel KLOV with the same ID so please Google my ID against KLOV if you would like some background showing I am legit.
Brent
Jonmkl
  • Last login:February 02, 2014, 09:28:39 pm
Excuse me, Do you still have this board?
if not Haruman has a CnD bootleg for like $75
I sure do.   :cheers:
Jonmkl
Haha what sort of boot is it? In my experience the boots all have major audio problems where the music doesn't play quite right.
If thats not the case then I am interested :-)
I can take a listen and see, I haven't noticed anything weird with the music before.  I can probably even make a couple of videos, too.
Jonmkl
Actually that would be cool :-) What type of boot is it? Single board or multi board?
Single board
