Author Topic: Dynamo Cabinet Open Back  (Read 1169 times)
brained
  • Last login:May 24, 2026, 09:06:19 pm
  • Raised by Atari
    • Nux
« on: March 08, 2013, 01:36:54 pm »
Hi Guys, I'm going to mount a 21" monitor into a HS-5 Dynamo cab, but the problem is that I think I need to decase the monitor because its too bulky. Most Dynamo cabinets I've seen have an open back, is it safe to leave the back open with a decased monitor or should I cover the back?
I have a three year old, and I know children have a lot of creativity....
BTW, I'm going to decase the monitor during the weekend, I know this question has been asked 10,000 times, but do I really need to discharge the monitor before handling it?
TIA
thatpurplestuff
  • Last login:May 25, 2026, 01:19:53 pm
Re: Dynamo Cabinet Open Back
« Reply #1 on: March 08, 2013, 01:59:03 pm »
I'm not an expert but I did work with a decased 32" sony trinitron a few weeks ago without discharging it (I read that they discharge themselves relatively quickly and the thing had been uplugged for 1.5 years).  One thing I would say is that you should absolutely have the back of the cab closed with a young child around... if they were to pull that anode cap off that could be extremely dangerous for little fingers.
edit: I meant that my specific TV (the 32" Sony Wega Trinitron) discharges itself quickly... not all CRT's do so you've gotta look up info on your particular CRT.
« Last Edit: March 08, 2013, 02:16:34 pm by thatpurplestuff »
brained
  • Raised by Atari
    • Nux
« Reply #2 on: March 08, 2013, 03:02:34 pm »
Where did you find the info about the discharge time?
sharpfork
    • KADE
« Reply #3 on: March 08, 2013, 05:24:01 pm »
I have a 27" in an hs5 decased, I expect a 21 would fit time still in the case.
If you open it up, discharge it.  I made a "chicken stick" to do this, a long ass PVC extension you add to a screwdriver to make a super lo g, insulated handle.
I mostly keep the back off (only the top half on an hs5) but made is up against a wall so it doesn't matter much.
SIII + Cyanogen + Tapatalk 2
