Author Topic: Pentranic Arcade Monitor - Intermittent Buzzing Problem  (Read 1459 times)
s34n
  • Last login:July 13, 2016, 01:30:42 am
« on: March 06, 2013, 01:17:56 am »
I left a machine sitting around for about a year or so, the machine was fine before, then suddenly nothing displays on the screen. I opened the back and I could hear intermittent buzzing coming from the monitor.
If anybody has any schematics or any reasons why this is happening, then please share! I can get the chassis number if required.
Here is a video of the buzzing... The lamp DOES light up on the tube (Can't tell from the video).
Thanks for any insight!
dgame
  • I am no Jedi
Re: Pentranic Arcade Monitor - Intermittent Buzzing Problem
« Reply #1 on: March 06, 2013, 09:40:13 am »
I was getting a similar buzz in my Wells D9200 and it turned out to be the surge protector.
When I googled the buzzing problem most suggestions pointed to something being wrong in the power circuit.
First I thing I tried was plugging it straight into the wall and the buzzing went away. Then I switched surge protectors.
Not saying that this is what your problem is but it can't hurt to try.
grantspain
  • Last login:Today at 07:14:10 pm
« Reply #2 on: March 06, 2013, 06:09:53 pm »
if you have tube heaters and hear static on power up then monitor should be working
turn up screen volts on flyback transformer a little to see if you get a raster
