Author Topic: Dimensions Question  (Read 3628 times)
avoryx
  • Last login:March 06, 2013, 09:03:04 am
Dimensions Question
« on: March 05, 2013, 05:45:34 pm »
I hope i'm posting to the right board, i'm new here.
I got an xarcade tankstick for Christmas, and i'm constructing a stand for it.
What is the average height (from the ground) for arcade sticks?
We don't have any arcades around me, and i would like it to feel just right...
I know a lot of cabs are different, but i'm talking a modern fighting game cab.
Thank you for any help.
avoryx
Re: Dimensions Question
« Reply #1 on: March 05, 2013, 05:53:42 pm »
if there are existing guides on this, feel free to point me that way... :burgerking:
shponglefan
« Reply #2 on: March 05, 2013, 09:27:05 pm »
Not sure of an actual average, but I would wager around 3 feet.  I know in the Project Arcade book, the height from the base to the bottom of the control panel box is listed at 33 inches.  And then it's probably another 3-4 inches or so to the top of the CP.
But rather than picking a number based on other arcade cabinets, I'd build something that works for you.  After all, if you're primarily using it, you should make something that is comfortable for yourself.
  • Last login:Yesterday at 01:21:33 pm
« Reply #3 on: March 06, 2013, 12:11:23 am »
+1 on adjust the height to you.
Take a small table and add/subtract books stacked under the tankstick until you find the perfect height.
If possible set it up so you can play your favorite game on it for a while -- just to be thorough.   ;D
a1pharm
« Reply #4 on: March 17, 2013, 10:34:32 am »
Take a look at my build, I have a blueprint of my cab drawn to scale on graph paper using inches.  I tried to find an average of what I found on these forums for all relevant heights and angles.  I used a 5degree slope for the control panel, and a 15degree angle for the LCD.  The top of the back of the CP is 39 inches off the ground.  I am 5' 10" (right in the middle of the bell-shaped curve for the height of a USA male).
The dimensions I chose are perfectly matched to my dimensions.  If you are taller/shorter, adjust the CP height by the same amount.  If you have questions, PM me, I spent a boat load of time researching answers to every possible measurement question you could think of.
my build:  http://forum.arcadecontrols.com/index.php?topic=129725.0
