Author Topic: unable to load startup.wav error?  (Read 1072 times)
peterpiper70
  • Last login:November 05, 2025, 02:59:07 am
« on: November 06, 2003, 05:41:48 pm »
I have developed a problem whereby when I start my machine, arcadeos seems to load okay until it comes up with an error
`unable to load startup.wav bad command or filename`
it then stops loading and just sits there like that. If i go in to arcadeos.cfg it has reset the sundcard from 1 to 0.
I know my soundcard is okay as uf I run `advmame romname` from a command line the sound works okay!!
Any ideas guys?
regards
pete
