Author Topic: Small fuse on chassis - size and type? KT-2182F  (Read 1139 times)
Midcoastsurf
  • Last login:November 02, 2020, 11:19:14 am
  • I want to build my own bartop
« on: March 04, 2013, 04:36:50 pm »
Hello,
I need to order a fuse (3.15A, 250v).  This fuse is a mini fuse, but I am not sure what the length/diameter is.  The wire inside the glass is thin and straight and has two beads positioned at equal points on the wire.  Fast-blow?
I have 3A fuses that are slow-blow and the same size, but wasn't sure if I should be using these in place of the 3.15A fuse.  Here is the data from the manual:
1 50-21X215BDA 215 250V 3.15A
lilshawn
  • Last login:March 16, 2026, 03:44:11 pm
Midcoastsurf
Re: Small fuse on chassis - size and type? KT-2182F
« Reply #2 on: March 05, 2013, 04:19:25 pm »
Yeah, looks like you are right.  5x20mm.
