Author Topic: Is it possible to map multiple controllers to Nestopia??  (Read 5433 times)
willybeamish
  • Last login:December 22, 2014, 01:59:10 pm
« on: February 26, 2013, 09:57:42 am »
I have currently a tankstick setup for player 1 and player 2..now I have the Retro usb adapters and two NES controller. I saw in the setup there is a option for controller 1,2,3,4. I mapped the NES controllers to controllers 3,4 thinking maybe it would work as additional controllers. However this was not the case it must be intended for the few 4 player games out there. Is it possible to keep the mapping on both my tank stick and these 2 nes controllers??
Currently rebuilding a PP cab and converting it to a mame cab..view the progress here http://forum.arcadecontrols.com/index.php/topic,122815.msg1305024.html#msg1305024
zanna5910
  • Last login:August 05, 2024, 10:37:36 am
Re: Is it possible to map multiple controllers to Nestopia??
« Reply #1 on: February 26, 2013, 03:56:43 pm »
i never got it to work to map multiple inputs to one Player.  I just stick with the controller since its original.  I would also like to say there are some other great NES ems out there and I eventually went with JNES because of the RGB filters.  NESTOPIA crashed my config files so many times with mapped controllers and exit crashes.
willybeamish
Re: Re: Is it possible to map multiple controllers to Nestopia??
« Reply #2 on: February 26, 2013, 04:08:17 pm »
Not a bad idea maybe ill keep it on the controllers instead of the sticks since it will ramp up the nostalgia a bit more. And so far Nestopia has been good to me but ill keep it in mind about jnes if it breaks balls.
