Author Topic: setting up a 60 in 1 jamma board for two players alternating with one joystick  (Read 13655 times)
mebronx2000
  • Last login:December 25, 2025, 09:47:47 pm
i have a pac man upright with one joystick and 3 action buttons and a one and two player start button ... i hooked up me jamma button to the one player controls and i wired the player 2 button to the player 2 start on the jamma harness and i have me board set for 1player upright how do i get it to play 2 players alternating with the one joystick ? thanks   :banghead: :notworthy:
mebronx2000
anyone please  :banghead: :cry: :badmood: :badmood: :badmood: :dunno
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
I'm not sure I understand the question -- pretty much all of the games on there are alternating single stick games. Do you have it set for cocktail mode perhaps ?
Working: Not Enough
Projects: Too Many
Progress: None
mebronx2000
i have it set on upright 1... on the jamma harness it has 1 player hookup wires and a 2player wires so on my joystick i have the one player start hooked to the 1player start on the jamma harness and the 2player start hooked to the 2player start on my jamma harness ..but i cant play 2 players ? thanks  :notworthy:
Are you saying inserting 2 credits and pressing player 2 start doesn't start a 2 player game? Or a 2 player game will start but the joystick and buttons don't work for player 2?
If it can start a 2 player game, just wire up the controls to BOTH the player 1 pins and player 2 pins of the jamma connector.
mebronx2000
i have it set for free play ..and i am saying hitting the player 2 button does nothing it doesnt start a two player game thanks
Double check your wiring for proper crimps and connections and also possible opens (both in the signal wire and your ground circuit). Verify the signal wire is connected to the NO terminal of the microswitch and also verify you have continuity across the switch's ground pin and NO pin when the switch is made. Also, I've come across quick disconnect terminals that need to be pinched a little to make a proper connection with the switch spade, make sure yours isn't loose.
mebronx2000
thanks i will give those a try thank you for your help !  :notworthy:
CheffoJeffo
I don't think Free Play lets you play 2 player on the 60-in-1.
Working: Not Enough
Projects: Too Many
Progress: None
mines set on freeplay, no issues with 2 Player games.
mebronx2000
but do you have your 60 in 1 jamma board set for upright 1 control or upright 2 control thanks so much
the only dip thats on is the one that sets it to use 15Hz.
mebronx2000
i am not talking about dip switches i am talking about the setting !! :banghead:
I'll check tomorrow, Im 99% sure its set for 1player upright in fact 99.9%
mebronx2000
thanks for all your help guys !  :applaud: :notworthy: :cheers:
