Author Topic: Two simulataneous, different games on a dual display cabinet?  (Read 2396 times)
scrotty
  • Last login:October 08, 2018, 08:28:35 pm
« on: February 10, 2013, 02:42:57 pm »
Given a dual display cocktail cab like this one peteinbrum created (link on avsforums):
Is there a way to sometimes have the display simply mirror the exact same image (as the picture shows) AND, on occasion, allow the players to play completely separate games simultaneously?
In other words, sometimes the players would want to play the same game together and so would see the same image on their respective displays. But at other times they want to play completely different games as if this was two separate arcade cabinets that just happened to be joined under the same table. A Siamese Cocktail, so to speak.
TIA!
Sean
matsadona
Re: Two simulataneous, different games on a dual display cabinet?
« Reply #1 on: February 11, 2013, 03:57:21 am »
In theory it should be possible to run two parallel instances of MAME, assuming that you have different inputs mapped etc. However I have never tried it, and there might be reasons (bad coding or other dependencies unknown to me) why it isn’t possible.
However I have tried that exact thing with the SEGA M2 emulator…
scrotty
« Reply #2 on: February 11, 2013, 11:48:20 pm »
Thanks for the response, matsadona! I was hoping there was a single build of MAME that itself could manage running two simultaneous games. But given the lack of response I'm guessing not.
nexusmtz
  • Last login:July 23, 2026, 12:05:52 am
« Reply #3 on: February 17, 2013, 12:37:34 am »
Yo1Dog did this a few years ago. http://forum.arcadecontrols.com/index.php/topic,98933.msg1048073.html#msg1048073
Unfortunately, he hasn't been around lately, and I don't think he ever shared his code.
At least you know it's possible, and, for Yo1Dog, it was easy.
I did something similar to what you're looking for using two VMWare virtual machines and two gamepad hacks, but his method would be much more elegant for a MAME-only solution.
You might try sending him a PM to see if he still has the code on hand.
scrotty
« Reply #4 on: February 18, 2013, 10:10:50 pm »
Awesome! Thanks nexusmtz!
