Author Topic: Deleting ROMs based on mame.xml file  (Read 4720 times)
tommytutone
  • Last login:August 01, 2014, 07:14:12 am
« on: February 05, 2013, 09:18:20 pm »
I hope this makes sense. I have a large folder with MAME ROMs, and the MAME.xml file that lists them all. I am going through the .xml file, deleting fruit machines, pachinko, etc. I would like to delete the ROM files themselves (since they take up space but will never be played) based on the changes made to the .xml file. Is there a tool that will make this happen?
I know you can go the other way around, building an .xml file based on the ROMs you own, but I'm hoping to go backwards, so to speak.
Re: Deleting ROMs based on mame.xml file
« Reply #1 on: February 05, 2013, 11:04:09 pm »
Romlister can make a batch file that copies only games that are included in the xml file over to a new folder.
You just use your modified xml file as the source.
On MAME v.146, I went round and round modifying the xml file by hand and through romlister.
It didn't like using a Mala xml as the source, but somehow I got it to work.
Never did get the xml file small enough to attach to a post.  :lol
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #2 on: February 07, 2013, 08:50:52 pm »
Totally doable with romlister.
1) take your full xml file, merge it with the .ini files.
2) in romlister's main GUI, select all the genres you want *removed* from your list in the category section.
3) in the -find window remove all the text except the genres that you're trying to eliminate.  You'll end up with a chunk of text that looks like this:
 ('BIOS' | quiz | tabletop | Fruit_Machines)
4) put a ! (a NOT) in front of that text:
! ('BIOS' | quiz | tabletop | Fruit_Machines)
5) hit the go button to make a list.  the list now contains everything except the things you've specified.
6) Export that list as XML.
tada!
