Author Topic: MAME computer of choice???  (Read 1661 times)
koolmoecraig
    • My Intervention
« on: February 05, 2013, 12:59:06 am »
Accidently posted this in the wrong section before....
I've been out of the MAME scene for a while...What's the best self contained set-up nowadays for a machine geared towards early 90's games and prior? Is there some mini ATX rig that people like?  I'm going to be running it into a real arcade monitor.  Do I still need an ArcadeVGA card from Ultimarc?
Thanks in advance!
koolmoecraig
    • My Intervention
Re: MAME computer of choice???
« Reply #1 on: February 05, 2013, 01:18:00 am »
Micro ATX?
RyoriNoTetsujin
  • Last login:March 23, 2024, 03:55:45 pm
« Reply #2 on: February 05, 2013, 08:47:57 am »
You can get a system that runs everything that's currently playable in MAME (including the benchmark games like NFL Blitz) in a mini-ITX system these days, but you'll probably want to build it yourself. I built one here: http://forum.arcadecontrols.com/index.php/topic,129277.0.html  There are pictures further down the thread too.  Obviously, you're not going to use the m350 case if you're going to use a discreet GPU...
As I understand it, you don't necessarily need an AVGA anymore, as long as you've got a GPU that supports an app called Soft15khz. I'm not much of a help here, except to say that the Intel HD series of integrated graphics (i.e. Sandy Bridge and Ivy Bridge chips) do NOT currently support Soft15khz.
Alternatively, if you want to get really small but don't want to build your own, take a look at the Intel NUC, or the Core-based systems made by Giada PC. Again, harder to get output to an arcade monitor, but almost impossible to get that kind of power in a smaller device.
