Author Topic: USB interface for Happ 3" Golden Tee (red pcb)  (Read 1596 times)
X-fact0r
  • Last login:July 21, 2019, 03:04:59 pm
  • Cabinet build in progress!
« on: January 29, 2013, 10:24:43 am »
I've recently acquired a cheap used 3" Happ tb from a Golden Tee arcade.
In order to connect it to the PC I've googled and found some great sites with PS2/USB hacks. The problem is that I was unable to get it working with neither of the two machines I have atm (XP/Win7) and after messing with the HID driver settings I could get a erratic jerky movement of the cursor...
Is there a way that I can get this tb to work with mame?
Do I need an interface such as Opti-Wiz or the Opti-pac? Would these work with this red pcb tb?
Thanks.
                           ** Build thread | Art thread **
chopperthedog
  • Last login:Yesterday at 05:40:57 pm
Re: USB interface for Happ 3" Golden Tee (red pcb)
« Reply #1 on: January 29, 2013, 12:58:52 pm »
Sounds like a wiring issue in the mouse hack. My mouse hack from years ago has been flawless across xp and 7 never had to touch any settings. If you need a pic I can post one up.
good day.
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #2 on: January 29, 2013, 01:23:56 pm »
The Red PCB's are the new ones. I've got one in my 4-Player Cab.
You can get the Opti-Wiz with a plug-and-play harness. That's what I did, as I didn't want to deal with backspin, nevermind digging up an ancient crate of ball mice. :)
X-fact0r
« Reply #3 on: February 02, 2013, 09:10:36 am »
Thanks guys!
@chopper,
I followed the instructions on this website:
http://www.techdose.com/projects/Arcade-Trackball-Mouse-Hack/363/
I would appreciate if you could post a pic in oder to confirm functionality just before I trash some $$ on the Opti-Wiz ;)
