Author Topic: Advmenu and custom modeline?  (Read 4651 times)
emuola
  • Last login:June 15, 2017, 02:19:54 am
« on: December 20, 2012, 02:57:25 am »
I just realised that I can define a custom modeline for Advmenu so that the menu would be totally flicker free (atm its flickering a bit with the default cga-setting). However, I'm not sure how to do this in practice. Advmenu docs say the format is something like this:
Code: [Select]
device_video_modeline Name CLOCK HDE HRS HRE HT VDE VRS VRE VT [-hsync] [-vsync] [+hsync] [+vsync] [doublescan] [interlace]
and modeline from "Monitor presets" thread from this forum (for the m3129) would be something like this:
Code: [Select]
monitor_specs0    15450.00-16050.00, 55-65, 3.19, 4.75, 6.45, 0.191, 0.191, 1.164, 0, 0, 288, 448
The question is, what do I acatually put into advmenu.rc?  :dunno
Running GroovyArcade (64bit).
« Last Edit: December 20, 2012, 02:59:33 am by emuola »
Calamity
  • Moderator
  • Last login:Today at 01:04:27 pm
  • Quote me with care
Re: Advmenu and custom modeline?
« Reply #1 on: December 21, 2012, 06:15:37 am »
Hi emuola,
You don't need to add anything to advmenu.rc
Advmenu will use the modeline currently assigned to the X system. This one is defined in etc/x11/xorg.conf. You need to place a 31 kHz modeline in there. Use the resolution 648x480, there's a good reason for this. This should be automatically done by Switchres when you select your monitor type from gasetup, but the current version on the live-cd does not support the new monitor presets. An updated version is coming soon.
Steps to create a log:
emuola
« Reply #2 on: December 21, 2012, 07:53:42 am »
Hi emuola,
Ok, thanks again Calamity :) I think I'll wait for the next live-cd.
emuola
« Reply #3 on: December 21, 2012, 10:20:17 am »
Hi emuola,
One more thing: The reason I asked this in the first place was that I first had the advmenu with 648 x 480 (later switchedto 320 x nnn). The advmenu was ok, but the problem was that all the games that were more or less 320 x nnn were "squashed" from the right edge pretty badly. The only way to correct it was to adjust the display settings from the panel of the display itself (vpos/hpos/ etc).
I figured that I can only setup the display settings once (the m3129 does not havememory for different presets?), so that I really cannot have the advmenu in 648 x 480, becuse the games won't use that mode.
So: is there any way to get the advmenu "flicker free" in 320 x nnn?
Am I completely lost here or what?
As you can see, I'm really no pro here  :dizzy:
« Last Edit: December 21, 2012, 10:22:57 am by emuola »
Calamity
  • Moderator
« Reply #4 on: December 23, 2012, 10:23:26 am »
Hi emuola,
Sorry but that doesn't make any sense. Advmenu and GroovyMAME are totally independent in the resolutions they use.
You could have fixed the horizontal shift of your low resolutions by means of the crt_specs options in mame.ini, without altering the default settings of your monitor.
What I meant is that the new version of SwitchRes will allow you to have a modeline in AdvMenu that has the exact same geometry as the ones that GroovyMAME uses, this means that there will be no relative difference.
Of course. Any progressive mode will be "flicker free".
emuola
« Reply #5 on: December 23, 2012, 11:17:08 am »
Hi emuola,
Thank you, now I got it :) The next version of switchres is going to be reallly cool  :cheers:
[/quote]
Thanks again. I guess eventually this resolution/modeline stuff is slowly eating its way through my thich skulll  :lol
« Last Edit: December 23, 2012, 11:22:06 am by emuola »
