Author Topic: Can I used my old BlackBerry charger to charge my PS3 controller?  (Read 2718 times)
roywang
  • Last login:January 21, 2013, 01:11:41 am
I used to be able to charge my blackberry with the ps3 controller charging usb cord. So, now i am wondering if I can use my blackberry charger to charge my controller. Its the same plug in.
This would be way better cause if I'm charging my controller i have to sit way up close in order to play a game, which sucks.
________________
xbox 360 chargers wii chargers ps3 battery
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
Re: Can I used my old BlackBerry charger to charge my PS3 controller?
« Reply #1 on: December 18, 2012, 07:28:15 am »
Look at the back of the charger and check the output voltage.  If it matches the DC power requirement on the controller, and the polarity is the same you should be good.
If you're unsure how to check polarity, imagine the cable as having an inside metal part and an outside metal sleeve.  this diagram shows typical ways these are shown on power supplies etc.
Bringing to life a child's imagination.
« Reply #2 on: December 18, 2012, 07:58:32 am »
Ignore the above...  mini-usb are wired all the same way, you can use any mini-usb charger.
Dervacumen
    • Beaker Games
« Reply #3 on: December 18, 2012, 09:25:19 pm »
I guess that's what I get when I have neither a BlackBerry nor a PS3.
SNAAKE
  • Trade Count: (+29)
« Reply #4 on: December 29, 2012, 10:52:10 pm »
why did you even reply  :banghead:
and ps3 controller can be charged with any mini usb cable/charger. I do it from my computer.
