Author Topic: Track Ball - Static Electricity issue  (Read 1852 times)
cisrsb
  • Last login:December 29, 2012, 10:43:17 am
« on: December 08, 2012, 10:47:42 am »
Hi all,
I have a question about an issue which happened yesterday. I have an older SlikStik control panel which has a 2.25" Happ Control track ball in it. Yesterday I went to play it and I got a static electricity shock when I touched the metal plate around the track ball, now the 2 mouse buttons nolonger work (the trackball runs fine). I've plugged it into the other USB ports with same results. I plugged my USB mouse into each USB port and the mouse works fine so I'm guessing the mobo is fine. Do you guys think I might have fried my track ball circuit boards and would need a trackball unit replacement?
Thanks for any info.
Rudy
BobA
  • What Me Worry?
Re: Track Ball - Static Electricity issue
« Reply #1 on: December 08, 2012, 11:01:54 am »
Sounds like the static damaged the trackball usb/button interface.  The plate should be grounded to your cabinet frame ground to prevent this type of damage.   Most trackballs come with wires for this purpose.
cisrsb
« Reply #2 on: December 09, 2012, 12:33:35 pm »
Thanks BobA...
I've gone ahead an ordered a new usb interface...
http://na.suzohapp.com/trackballs/56011300k.htm
Hoping this does the trick.
-Rudy
cisrsb
Re: Track Ball - Static Electricity issue (THANKS BobA!)
« Reply #3 on: December 13, 2012, 06:28:31 pm »
Just a note to say Thanks Bob!
I receive the 2 circuit panels from Happ today and once I installed them my tackball buttons were once again operational.
I really appreciate your original response to my question.
-Rudy
BobA
  • What Me Worry?
« Reply #4 on: December 13, 2012, 08:14:17 pm »
Glad you got it sorted out.  ;D
