Author Topic: Wanted: Someone to compile MAME with extras  (Read 1173 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: December 06, 2012, 11:44:42 pm »
 I applied the patches but they didnt seem to hold :(  It says all hunks ignored, skip patch (y).   Here is what i am trying to add.  first file:  Its supposed to make it when you save/load, you just press 1 button and not have to press "1" after for a save slot.  The one after adds the "Z" axis for my spinner.  I will paypal u $20 to do this for me and maybe show me how you did it.
diff -c -r ..\/src/usrintrf.c ./src/usrintrf.c
*** ..\/src/usrintrf.c   Tue Nov 23 18:05:00 2004
--- ./src/usrintrf.c   Thu Dec 16 22:33:16 2004
*** 3940,3946 ****
        if (input_ui_pressed(IPT_UI_CANCEL))
           break;
!       code = code_read_async();
        if (code != CODE_NONE)
           if (code >= KEYCODE_A && code <= KEYCODE_Z)
--- 3940,3947 ----
           break;
!       //JOEY
!        code = KEYCODE_A; //code_read_async();
*** 4153,4166 ****
--- 4154,4173 ----
        if (single_step == 0)
           mame_pause(1);
+       // JOEY ADD PAUSE text
+       ui_text(bitmap, "GAME PAUSED", 100, 100);
        while (!input_ui_pressed(IPT_UI_PAUSE))
           profiler_mark(PROFILER_VIDEO);
           if (osd_skip_this_frame() == 0)
              /* keep calling vh_screenrefresh() while paused so we can stuff */
              /* debug code in there */
              draw_screen();
           profiler_mark(PROFILER_END);
*** 4206,4211 ****
--- 4213,4221 ----
           if (osd_selected != 0) osd_selected = on_screen_display(bitmap, osd_selected);
+ //         ui_text(bitmap, "GAME PAUSED", 100, 100);
           if (options.cheat) DisplayWatches(bitmap);
           /* show popup message if any */
*** 4220,4225 ****
--- 4230,4238 ----
           update_video_and_audio();
           reset_partial_updates();
  #ifdef MESS
           if (!setup_selected && mess_pause_for_ui)
*** 4238,4243 ****
--- 4251,4258 ----
        schedule_full_refresh();
  #if defined(__sgi) && !defined(MESS)
The 2nd one is to support "Z" axis for my spinner since trackball is using X and Y:
diff -Nru o3/src/osd/windows/input.c 3/src/osd/windows/input.c
--- o3/src/osd/windows/input.c   2010-02-13 09:30:18.000000000 -0800
+++ 3/src/osd/windows/input.c   2010-02-13 10:33:25.000000000 -0800
@@ -2098,7 +2098,7 @@
             // update zaxis
             if (data->usButtonFlags & RI_MOUSE_WHEEL)
-               devinfo->mouse.raw_z += (INT16)data->usButtonData * INPUT_RELATIVE_PER_PIXEL;
+               devinfo->mouse.raw_z += (INT)((INT16)data->usButtonData * 4.267);
          // otherwise, update it as a lightgun
