Author Topic: Sampo SME-32DL5 Any good for Mame?  (Read 996 times)
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« on: December 05, 2012, 12:40:54 pm »
I tried finding the specs, but can't find much or make sense of them. Will this work in like a tri-sync mode, or does this even go down to CGA resolution, like from Ultimarc-"A few high-resolution arcade monitors can display the entire range 15Khz - 31Khz ." Also if it will work is it auto switching?
  I am just wondering if this is better for Mame than a plain old CGA only or  LCD- Thanks
I THINK these are it
CRT:
Screen Size: 34 Inch SuperFlat CRT (32 Inch Viewable)
Dot Pitch: 0.80mm
Aspect Ratio: 4:3
Type: Invar Shadow Mask, Dynamic Focus
Horizontal Frequency:
15KHz/31~52Khz
Vertical Frequency:
50Hz ~ 120Hz
Resolution:
Max 1024 x 768 @ 60Hz
Bandwidth:
65Mhz
Display Area:
25.4in x 19.0in / 644.8 x 483.6mm
SIGNALS:
Audio System:
12W+12W High Performance Stereo with Subwoofer
RGB Signal Compatibility:
VGA, SVGA, XGA, and MAC
Video Signal Compatibility:
NTSC/PAL
Inputs:
Composite Video: Rear x2 (RCA Jack)
S-Video: Rear x1 (MiniDIN 4-pin)
Component: RCA Jack x1 (Y/CB/CR)
RGB: Front x1, Rear x1 (D-Sub 15-pin)
Audio: Rear x5 (RCA Jack, L/R)
Outputs:
Composite Video: Rear x1 (RCA Jack)
Audio: Rear x1 (RCA Jack, L/R)
RGB: Rear x1 (D-Sub 15-pin)
CONTROL PORT:
RS-232:
D-Sub 9-pin x1
GENERAL:
Power Supply:
100~240 VAC, 60/50 Hz
Plug and Play Compatibility:
DDC1, DDC2B
Regulatory Compliance:
TUV, UL, CSA, FCC-B, DHHS, CE, PTB
Power Consumption:
220W
Dimensions (W x H x D):
34.1in x 28.3in x 22.9in, (866 mm x 718 mm x 583 mm)
Net Weight:
156.5 lbs. / 71 kg
Optional Accessories: NTSC Tuner Card (181 CH/V-Chip, CCD)
