Author Topic: Advice wiring 4 way stick  (Read 2320 times)
hooddoctor
  • Last login:March 13, 2023, 09:45:28 pm
« on: December 05, 2012, 10:44:11 am »
Hey guys couldn't find good answer searching so need some advice.  Im wiring a 2 player cp with a dedicated 4way stick that will go to a minipac. How exactly do you wire the 4way to the 8way player 1? Is it simple as bringing both wire s together then for each direction then to the input on minipac? Thanks.
brad808
  • Last login:May 22, 2023, 08:18:15 pm
Re: Advice wiring 4 way stick
« Reply #1 on: December 05, 2012, 11:30:47 am »
Yes it's as simple as doubling up the wires.
The only real difference between the two is that one joystick allows you to physically hit two switches at once and the other will only physically allow you to hit one switch at a time.
Edit: just to clarify you don't want to use both at the same time do you?
Sent from my Galaxy Nexus
hooddoctor
« Reply #2 on: December 05, 2012, 10:26:29 pm »
No not using at the same time. The 4 way is a dedicated pacman/galaga stick. I have alot of buttons so on the minipac are limited to 32 inputs.
brad808
« Reply #3 on: December 05, 2012, 10:38:21 pm »
Then yes just double up the wires on the input. So both joysticks are gong to the same inputs.
GnobarEl
  • Last login:February 21, 2019, 04:58:34 pm
« Reply #4 on: December 06, 2012, 06:50:59 am »
Do you have any schematics of the connections?
  • Last login:Today at 03:56:07 am
« Reply #5 on: December 06, 2012, 11:47:24 am »
Looking for something like this?
When lines cross, a dot = connected and no dot = not connected.
« Last Edit: December 06, 2012, 11:50:56 am by PL1 »
hooddoctor
« Reply #6 on: December 06, 2012, 12:20:51 pm »
This was exactly what I needed thanks guys for helping out a noob.
Burn4Evr
  • Last login:January 20, 2016, 05:49:14 pm
« Reply #7 on: December 27, 2012, 02:42:48 pm »
You can also put a toggle switch on the ground wire to "lockout" one of the joysticks.
So there is no accidental pushing of the other joystick messing you up.
I think its a SPDT switch if I remember correctly.
paigeoliver
  • Awesome face!
« Reply #8 on: December 27, 2012, 04:31:15 pm »
My main cabinet which has a two player dualjoy layout plus a 4-way doubles up some of the wiring to get all the sticks active on a standard ipac. The hitting of the secondary sticks just never comes up.
