Author Topic: 60 in 1 board  (Read 2317 times)
mebronx2000
  • Last login:August 03, 2024, 06:20:32 pm
60 in 1 board
« on: November 28, 2012, 08:28:16 pm »
i am looking to make a cab with a 60 in 1 board does anyone know how to hook up joysticks and buttons? do i need an jpac or something and i want to use a coin mech and help please thanks :banghead: :cheers:
selfie
Re: 60 in 1 board
« Reply #1 on: November 28, 2012, 08:37:47 pm »
The 60in1 I used worked with a plain jamma harness
mebronx2000
Re: 60 in 1 board
« Reply #2 on: November 28, 2012, 08:47:18 pm »
i have an empty cab i want to know how i would hook up the joysticks and buttons !
ccmathome
  • Last login:February 25, 2021, 12:40:52 am
Re: 60 in 1 board
« Reply #3 on: November 28, 2012, 09:34:20 pm »
Google jamma pinout or if you have the booklet that comes with the 60in1 it's all in there
Sent from my SCH-M828C using Tapatalk 2
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
Re: 60 in 1 board
« Reply #4 on: November 29, 2012, 06:40:22 am »
You need to wire the can up JAMMA.
http://wiki.arcadecontrols.com/wiki/JAMMA
http://homearcade.org/BBBB/buildit.html
Working: Not Enough
Projects: Too Many
Progress: None
CraftyMech
  • Trade Count: (+9)
  • Last login:July 29, 2023, 08:08:45 pm
  • I love the smell of solder in the morning...
    • craftymech.com
Re: 60 in 1 board
« Reply #5 on: November 29, 2012, 12:13:58 pm »
As everyone else has said, get a Jamma harness and you are set. They can be had on eBay for $10-15 including shipping. The harness has connections for everything from the coin slots to the service switch.
BitKit 8bit FPGA Multi - http://craftymech.com
CheffoJeffo
Re: 60 in 1 board
« Reply #6 on: November 29, 2012, 12:35:10 pm »
Additional note: be sure to wire up the TEST and SERVICE switches for easier access to the configuration menus. I mount mine just inside the coin door for easy access.
Working: Not Enough
Projects: Too Many
Progress: None
mebronx2000
Re: 60 in 1 board
« Reply #7 on: November 29, 2012, 06:03:59 pm »
thanks everyone for your help  :notworthy: :cheers:
