Author Topic: Mitsubishi projection monitor vs50se1  (Read 1724 times)
BC_Jeffro
  • Last login:March 09, 2020, 04:55:23 pm
  • you can never leave the game!
« on: November 28, 2012, 04:10:04 pm »
just picked up a fighting vipers deluxe from 1995 (free) with a Mitsubishi  projection monitor vs50se1 that has had a virtual strikers 2 put in
the VS2 board works kinda not all leds were on and had picture but was all green
there was also a jamma harness in the cab so i witched to that but i cant get it to sync
the RGB and the ground and sync are hooked up right
« Last Edit: December 04, 2012, 01:16:18 am by BC_Jeffro »
BC_Jeffro
Re: Mitsubishi projection monitor vs50se1
« Reply #1 on: December 03, 2012, 09:09:09 pm »
the beast
known working S buster bros test has sound plays but out of sync
is this a med rez monitor?
« Last Edit: December 03, 2012, 09:12:16 pm by BC_Jeffro »
grantspain
« Reply #2 on: December 04, 2012, 05:09:48 pm »
yeah wrong resolution,you can see 2 images
i am pretty sure these were 24khz only monitors
the bnc connectors go to a circuit board in the front unit-i do not remember if these were a decoder or just some kind of signal/sync splitter
BC_Jeffro
« Reply #3 on: December 07, 2012, 09:22:15 pm »
i think you are right it is a 24k only
thats way the VS2 board worked and jamma did not
BC_Jeffro
« Reply #4 on: December 12, 2012, 02:01:35 am »
and the board in the front unit dose not covert   :hissy:
and all the converter boards out there (within reason there are some pricy ones) only output at 15k sure they will take any 15-31k but only output 15k threw RGB
« Last Edit: December 12, 2012, 02:04:05 am by BC_Jeffro »
