Author Topic: Looking to hook to a 27" TV  (Read 2703 times)
jmarket
  • Last login:February 14, 2014, 09:30:34 am
« on: November 19, 2012, 10:04:29 pm »
I have a PC that has VGA out and also DVI out. The bad thing is the TV is old and just has composite and s-video. I have read on here that some people use s-video so that is my plan as of now. The problem is trying to get from VGA or DVI to s-video. I was able to get an ATI Radeon x1300 free but it will not work in the computer that I am using because I do not have a PCI Express 16 port. The port that I thought was a PCI Express 16 was actually an ADD2/SDVO port. So the only ports i have are two PIC ports and a PCI Express 1. I guess my options are below unless anyone knows anything else.
1. Try to find an old standard PCI card with s-video.
2. Buy a VGA to s-video converter box that will input VGA and give me s-video out.
Any other options?
MonMotha
Re: Looking to hook to a 27" TV
« Reply #1 on: November 19, 2012, 10:29:03 pm »
Odd that a system with video outputs already on the motherboard would have an SDVO slot that cannot also act as PCIe.  What model PC is this?
Your easiest is to probably just get a different PC, but if you can convince the onboard video to run at native TV resolution (15kHz timings), you can use an RGB to S-Video converter, and the results are generally quite good (in most cases much better than using the scaled S-Video outputs present on most video cards).
jmarket
« Reply #2 on: November 19, 2012, 10:34:42 pm »
It is an HP rp5700. builtin VGA and the DVI card is in the  ADD2 slot.
http://h10010.www1.hp.com/wwpc/us/en/en/WF06a/12454-12454-64287-321881-3328896-3375897.html?dnr=1
Not sure what you mean by  " convince the onboard video to run at native TV resolution (15kHz timings), you can use an RGB to S-Video converter"
« Last Edit: November 19, 2012, 10:39:51 pm by jmarket »
MonMotha
« Reply #3 on: November 19, 2012, 11:04:14 pm »
Oh, they've got the DVI on the SDVO.  You sure that thing can't run as PCIe, too?  That was one of the whole points of the SDVO spec.  I could see HP being cheapskates and not making that possible, though.
Regarding making the onboard video run at TV timings, find the "Soft15kHz" thread.  There's other ways to do it, but that's a popular one.  The idea is that you make the VGA output run at a TV-compatible resolution (480i or 240p).  It won't work with a PC monitor at this point, but you can use an RGB to S-Video converter (tons of options available) to hook it up to your TV using S-Video.  The results are usually pretty decent, though it depends on the quality of your TV.
jmarket
« Reply #4 on: November 19, 2012, 11:13:20 pm »
Yeah I am pretty sure it wont run PCIe also because I put the ATI Radeon x1300 in the slot and it came up with a post error saying it only supports ADD2 cards. When i went to take out the card I noticed it actually said on the board next to the slot ADD2 cards only or something like that.
Looks like  "Soft15kHz" doesnt support my onboard Intel GMA
« Last Edit: November 19, 2012, 11:23:50 pm by jmarket »
MonMotha
« Reply #5 on: November 19, 2012, 11:27:57 pm »
Awesome.  Score one for HP.
I know the Intel hardware is capable of running pretty much any video timings that you want (I've done it on Linux), but the Windows drivers may not support it.  If indeed that's the case, your only option left is a scaling VGA to S-Video adapter ("scan converter").  They're cheap (~$25-35 on the 'bay), but don't expect it to look particularly good, probably not much worse than the output built into e.g. that x1300, though.
jmarket
MonMotha
« Reply #7 on: November 20, 2012, 01:41:27 am »
Example of the "scan converter" I was referring to.  This will take common "VGA" signals and mash it to fit on a TV.  The results aren't great, but they should be comparable to the S-Video output on most PC video cards, and this particular one is quite cheap.
http://www.amazon.com/PC-To-TV-Video-Converter/dp/B001CJOLBW/ref=sr_1_1?ie=UTF8&qid=1353393603&sr=8-1&keywords=scan+converter
