Author Topic: Config to use with AVGA  (Read 1875 times)
MBaran
  • Last login:December 29, 2020, 08:34:56 pm
« on: October 29, 2003, 10:16:03 pm »
With an arcade vga card, and Mame, with the front end mamewah, should i need anything special. Does anyone have a custom cfg file that works well with avga. Also, would i need to configure anything else. I tried a scan converter, but it did not work as planned, because it cannot support under 640x480. Thanks for all the help.
SoooPig
  • Last login:July 02, 2004, 07:40:06 pm
  • Wooohoo!
Re:Config to use with AVGA
« Reply #1 on: October 30, 2003, 09:22:27 am »
Have you experienced a specific problem, or are you just trying to get it right the first time?
Here's what I did...
Installed ArcadeVGA + drivers.
Installed Official MAME.
Installed Mamewah.
Ran AVRES to set all the resolutions for my roms...
All games played to date run in perfect resolutions.
MBaran
« Reply #2 on: October 30, 2003, 01:32:30 pm »
That definitely sounds like what i wanna do to get it right the first time. I have tried using AdvMame, and running 15khz straight to my monitor, but it doesnt wanna work. I will for sure order that card, and get it right the first time. Thanks
