Author Topic: Wells Gardner issue -screen "collapse" WG 19K49xx? Ms Pac Cocktail  (Read 2187 times)
twobad
  • Last login:June 11, 2013, 03:59:53 pm
I did a cap kit on a "speedy" MsPac which I believe to be one of the 19K49xx series models.  That solved all the "poor image" issues and worked for about a month.  Now, after a few minutes of the machine being on the screen "slams" to a narrow band as shown in the pictures below.  Bumping on the glass and/or coin door (vibration) may or may not cause the image to revert to normal, only to "collapse into itself" again. :banghead:
I'm suspecting a cold solder joint but would like your opinion on what the likely cause is or if the pictures allow a specific component to be judged as the culprit to prevent unnecessary "work" on an old chassis / machine.
Picture one is the "normal" screen.  The other three are the "collapsed" pics.
Sincere thanks,
-=T=-
MTPPC
Re: Wells Gardner issue -screen "collapse" WG 19K49xx? Ms Pac Cocktail
« Reply #1 on: November 15, 2012, 09:35:47 am »
Cold solder joint if vibration affects the failure mode and failure mode is heat dependent.
http://pinballmd.com/
buffett
  • Last login:December 13, 2016, 01:28:10 am
« Reply #2 on: November 15, 2012, 09:15:43 pm »
check all the solder and traces around your vertical transistors Q302-303.
also check the transistors for broken legs i have seen this before.
Peace
Buffett
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
twobad
« Reply #3 on: November 17, 2012, 12:55:09 pm »
thank you so very much! :cheers:
twobad
« Reply #4 on: November 21, 2012, 07:47:59 am »
Q302 and 303 appeared to be intact.  Wiggling C301 that I had replaced during the cap kit revealed a "color change" on the component side of the board without apparent movement of the capacitor.  Reflowing the solder on the "color changing pad"appears to have worked...  I know that's not a good description but I can not think of a better way to describe it- even under magnification when I put pressure on the cap, one of the solder pad edges of the PCB appeared to have "color change"...
Thanks again,
-=T=-
buffett
« Reply #5 on: February 01, 2013, 04:45:25 am »
just wanted to check if this was fixed.
if not do you still need help.
i could not tell from your last post.
also check out my youtube channel for monitor repairs i have done.
https://www.youtube.com/user/buffett1978?feature=mhee
Peace
Buffett
twobad
« Reply #6 on: February 01, 2013, 06:54:53 am »
You nailed it in your previous post, Sorry I was unclear.  My next door neighbor is in declining health and as soon as I reflowed the transistors, I took the machine to his house and haven't seen it since.  Thanks for the advice and the follow up.  You are "the bomb"!!   :notworthy:
thank you again,
-=T=-
buffett
« Reply #7 on: February 01, 2013, 03:17:42 pm »
cool cool happy to help.
glad you got it going for him.
thanks for the clarification.
it helps others as well.
Peace
Buffett
