Author Topic: get monitor to rotate 90 degrees/cocktail cab  (Read 2832 times)
ggnuncleb
  • Last login:October 16, 2003, 07:05:34 pm
« on: October 26, 2003, 07:38:19 am »
i need to get mame to rotate 90 degrees on my cocktail monitor. i got the monitor for nothin thinking i could use it but i can't because of this help. ??? ???please
sjcollier
  • Last login:November 09, 2003, 04:16:51 pm
Re:get monitor to rotate 90 degrees/cocktail cab
« Reply #1 on: November 09, 2003, 08:27:16 pm »
I am a fellow newbie, so bare with.  You can rotate your screen using "pivotTBYB" or in the MAME32 interface right?
paigeoliver
  • Awesome face!
« Reply #2 on: November 10, 2003, 04:51:10 am »
You should be more specific as to what you are trying to rotate.
To rotate a game with a command line version of mame, just launch the game with -rol or -ror. (Or change the setting in mame.ini).
For Mame32 you can change the setting in the menu (it is under video I believe).
Now for a rotated frontend. You can go the hard route (pivot software and Mame32, or any newer nvidia drivers if you have an nvidia card), or you can use a frontend that supports rotation. A lot of them do, I am personally using advancemenu on one vertical cabinet and game launcher on another. (Be sure and download that second configuration utility listed on the gamelauncher site). If you are using dos, then arcadeos rotates too, I used to use that.
eightbit
  • My cab is never done...
« Reply #3 on: November 18, 2003, 01:28:57 pm »
Can mamewah rotate or do I need to rotate windows for mamewah to work vertical?
rockhopper
  • Last login:December 26, 2015, 05:15:36 pm
  • I love orange soda!
« Reply #4 on: November 19, 2003, 04:57:20 pm »
Can mamewah rotate
I wanted to ask the same question, if not is this going to be possible in upcoming versions Minwah?
