Author Topic: Painting ...  (Read 2112 times)
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
Painting ...
« on: October 23, 2003, 06:09:05 am »
Hi guys,
I've finished the woodworking on my cabinet. Next step on the list is Painting.
From what I've read arround, the best finishing is achieved with pistol painting so I bougth a little air compressor (24 l) and it came with the painting set and other accessories. As it was in a promotion I belive it was a fair price for all (89,95
Re:Painting ...
« Reply #1 on: October 23, 2003, 07:57:24 am »
Your best bet would probably be an alkyd primer.  Use a thin coat, sand it after drying, and repeat.
PedroSilva
  • Grettings !
Re:Painting ...
« Reply #2 on: October 23, 2003, 08:16:30 am »
Hi,
What's an alkyd primer ? Don't know expression .. is it a syntetic one ?
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
Re:Painting ...
« Reply #3 on: October 23, 2003, 12:12:05 pm »
Water based generally = latex right? Should be fine...just don't saturate (like the can say's...thin coat)
All Your Base Are Belong To Us!
Re:Painting ...
« Reply #4 on: October 23, 2003, 12:14:00 pm »
It's a solvent based primer, not water based.  Here's an example of one:
Benjamin Moore Fresh Start Int/Ext All Purpose Alkyd Primer
That's what I would recomend.   8)
Hope this helps you.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:Painting ...
« Reply #5 on: October 23, 2003, 01:40:53 pm »
Did you buy the spray gun to paint on side art (like an airbrush) or just to paint the primer and base color (e.g. black).
PedroSilva
  • Grettings !
Re:Painting ...
« Reply #6 on: October 23, 2003, 07:19:20 pm »
Hi,
Thanks for your help ... I'm not an expert on painting jobs ... anyway answering the last question, ... I bought it to do all the painting ... not just the primer. Why ? Anything I should be aware of ?
papaschtroumpf
  • Have a Cow!
Re:Painting ...
« Reply #7 on: October 24, 2003, 12:16:09 am »
Nope, I've been toying with the idea of painting my own sideart but I'm not sure I have the skills to pull it off, I want it fancy.
PedroSilva
  • Grettings !
Re:Painting ...
« Reply #8 on: October 24, 2003, 05:58:52 am »
I see what you mean ... anyway ... I've not yet decided if I'll put sideart on in, but if I decide to do it, I'll supply the equipment but it sure ain't gone be me a do the painting  :)
I have a cousin who is very good on that ... he even has a specific set of "little" pistols for the job ... he does helmut (don't know if it's sppeled like that) painting ...
