Author Topic: Wells Gardner k7000 degaussing issue???  (Read 3840 times)
mandobear
  • Last login:April 30, 2013, 12:43:36 am
« on: November 01, 2012, 12:01:29 am »
My roommate stored his full stack guitar speaker cabinet right next to my arcade rig and was left there for a few days. Naturally my 25" wells gardner k7000 screen became discolored so after some research I went with the corded drill method and for the most part the colors went back to normal except that all the green is now red and all the reds are practically black. The drill method does nothing to fix this but I have noticed however that when I tilt the monitor downwards the colors come back to normal towards the bottom of the screen but go back to the crappy colors when I put the monitor back up.
What can be done to fix this problem? Is a degaussing wand my solution although the drill can't do it?
adder
Re: Wells Gardner k7000 degaussing issue???
« Reply #1 on: November 01, 2012, 12:19:31 am »
repair the degauss circuit of your monitor which it seems is not functioning
(buy a replacement thermistor to start, as perhaps yours has gone bad)
if necessary check/replace the other components in the degauss circuit also. there wont be many to check
finally check the degauss coil itself (the wire surrounding your monitor screen edge) for damage/short circuit
alternative solution: buy a manual degauss wand/coil on ebay. however i have never used one so cant comment on effectiveness. i found some instructions though (for coil... no idea if method is same for a wand):
Hold the coil out in front of you and switch it on. Approach the middle of the picture tube as you swing the coil around in a small circle. Wipe it across the face of the tube in slowly widening circles. Take about five circles to get out to the outside perimeter of the screen and back away from the screen slowly as you continue to make big circles. When you have backed up a couple of feet and you are no longer effecting the picture, shut the coil off.
« Last Edit: November 01, 2012, 12:26:05 am by jadder »
buffett
  • Last login:December 13, 2016, 01:28:10 am
« Reply #2 on: November 02, 2012, 05:34:10 am »
you need a proper degaussing coil to get your monitor back the way it should be.
Peace
Buffett
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #3 on: November 02, 2012, 06:27:21 pm »
Try this one.  It works well and is relatively inexpensive.  You can shop it out for even less.
http://www.amazon.com/Waldom-Degaussing-Coil-Color-Power/dp/B00011UYJU/ref=sr_1_1?ie=UTF8&qid=1351895183&sr=8-1&keywords=degaussing+coil
buffett
« Reply #4 on: November 02, 2012, 06:49:33 pm »
that is the one i have and it is the the best.
Peace
Buffett
