Author Topic: mamewah snapshot problems?  (Read 3307 times)
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« on: October 16, 2003, 06:10:59 am »
i am using the CAVE layouts in the latest version of mamewah.
No matter how many times i have tried, i can not get any snapshots to be displayed in mamewah. (The cave layouts allow two graphic, snapshot and a title perhaps).
In the artwork section i do.. c:\mamewah\mame\snap
but it doesnt display anything.
I also have tried this on my SNES emu too, and no screenshots are being displayed for that either.
Ive tried searching this place, but i found no answer.
Please help!
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
Re:mamewah snapshot problems?
« Reply #1 on: October 16, 2003, 01:05:57 pm »
If I am not mistaken, the path for snaps should be:
c:\mame\snaps
(or whatever drive MAME is on)
-Tom
« Reply #2 on: October 16, 2003, 01:16:46 pm »
Please help!
Open Cave's layouts in the Layout Designer, and see which Artworks #'s he used for his layouts.
Then open MAMEWAH, and check that the 'Artwork #? Path's are correct for each type of artwork.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #3 on: October 16, 2003, 03:41:03 pm »
Stuzza's page has many layouts for mamewah 0.935 but refers you to a different page for later versions. Does that means that you can't use the older layouts with the new version?
lildivaaa
  • Last login:January 12, 2009, 01:34:00 pm
    • That 80's Band
« Reply #4 on: October 16, 2003, 04:05:45 pm »
I've been able to user both the .935 and the higher versions with MAMEWAH. I'm currently running .962 with no problems with any of those skins.
Later,
Craig
Cave
  • Last login:June 07, 2009, 10:27:58 am
« Reply #5 on: October 16, 2003, 06:18:44 pm »
the MAME artwork should be like this
Artwork #1 Image Path = C:\MAME\SNAP
Artwork #2 Image Path = C:\MAME\FLYERS
replace C: accordingly or maybe your missing the paintX.dll, this would happen if you just copied mamewah to another computer instead of installing it.
papaschtroumpf
  • Have a Cow!
« Reply #6 on: October 16, 2003, 06:39:20 pm »
I have just started playing with making my own design and it's so easy! (well except for coming up with art that looks good). Thanks Minwah!
RedSquirrel
« Reply #7 on: October 16, 2003, 06:50:33 pm »
AHA thats probably why! I installed mamewah on the HD in this comp, before moving it over. I just hope its not gonna erase all my settings if i re-install over the top of it.
« Reply #8 on: October 17, 2003, 09:09:42 am »
They do work, BUT they will require some renaming and placing in the correct folder.  Read the latest Layouts.txt for details...
