Author Topic: Low res mode  (Read 2413 times)
mattr69
  • Last login:May 01, 2020, 05:24:01 pm
Low res mode
« on: October 26, 2012, 07:39:18 pm »
Hi,
I run MaLa on a 15kHz display in 320x240 resolution. Using the menus for game info, game lists etc is painful. There is an option for < 240 x320 display in the GUI which I think is supposed to help with this. It seems to be associated with INI file option SmallMenu. Howeverm when I select the option in the GUI it resets each time MaLa starts. I have confirmed this by manually setting the INI file value.
Loadman - Is this a bug? Do you have any suggestions?
PS Look forward to v1.8 coming soon!
Cheers,
Matt
mattr69
Re: Low res mode
« Reply #1 on: November 03, 2012, 11:10:43 pm »
FYI. Anyone that's interested. You need to set the lorez mode in the layout. It will automatically set  smallmenu in the mala ini.
