Author Topic: hd4870x2  (Read 2990 times)
limner
  • Last login:June 08, 2015, 06:59:42 pm
hd4870x2
« on: October 14, 2012, 06:18:33 pm »
anyone tried this card with crt_emudrive and groovymame?
i'm going to mount it on a Windows XP 64bit version linked to a Wells Gardner D9400.
Ah...i was forgetting...
1) this card has two  DVI port (no vga)
    Is a dvi<-->vga converter enought?
2) both DVI port can be used with crt_emudrive ?
krick
  • Gotta have blue hair.
Re: hd4870x2
« Reply #1 on: October 16, 2012, 02:22:31 pm »
I have no idea if it will work.  My understanding is that it is essentially two cards in one.  The older 9.3 Catalyst drivers that CRT_EmuDriver is based on supposedly support that card, but you'll probably have to give it try to make sure.
Yes, you need to use a DVI to VGA converter dongle.
Typically, only one port will work correctly with CRT_EmuDriver.  It's usually (but not always) the "bottom" port on the card (the one that is closest to the motherboard).
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
