Author Topic: JAMMA setttings  (Read 1156 times)
aj6500
  • Last login:July 29, 2003, 06:17:31 am
  • Does this rash look contagious?
JAMMA setttings
« on: October 11, 2003, 02:29:33 am »
My brother just picked up a fully functioning Jamma cab with mortal kombat 2 in it for $200.  We would like to know how to access the bios/dip switches or whatever is used to change settings on the game, specifically vollume and difficulty.  Any help would be appreciated.
They say patience is a virtue, and ignorance is bliss.  So I guess you can have a pretty good life if you're stupid and don't mind waiting around.
OSCAR
    • Oscar Controls
Re:JAMMA setttings
« Reply #1 on: October 11, 2003, 02:56:42 am »
If you have a real MKII cab, there are volume buttons and a test switch mounted on a bracket inside the coin door.
If it is a conversion...  ???
If you can get a manual for MKII you should be able to find which pins on the boards that the volume and test switch buttons would be wired to.  If those buttons aren't present, you probably want to add them.
Vol
  • Last login:June 25, 2007, 11:02:18 am
  • Mame Kabinet II in the works!
Re:JAMMA setttings
« Reply #2 on: October 11, 2003, 09:23:44 am »
KLOV has this link to the MKII manual.  It's a pdf scan of the actual manual.
http://www.arcadedocs.com/vidmanuals/M/MortalKombat2.pdf (6 MB)
