Author Topic: Ice Cold Beer Slider Frame + assembly  (Read 1840 times)
SavannahLion
« on: October 08, 2012, 03:57:49 pm »
I'm stumped. I've resolved nearly every component except this one. (and the ball return... And the shell mount.....etc but those are for later....)
I just can't seem to simplify and build my own comparable part while still keeping it a reasonable size.
I figured using a LM8UU or comparable linear bearing would do the trick. But I just end up with a lot more bulk just to transfer the motion across. I suppose I could brake a piece of aluminum but those dimensions work out to be pretty trim... Not to mention mounting the linear bearings.
Any ideas?
lilshawn
  • Last login:July 01, 2026, 04:44:09 pm
Re: Ice Cold Beer Slider Frame + assembly
« Reply #1 on: October 09, 2012, 02:39:37 pm »
0riginally they just used plastic sleeves.
Maybe get yourself a big thick plastic board...something made out of polyethylene (UHMWPE). (as it will have a slippery "self lubricating" property but still be hard) it's often used as wear material on assemblies where chains or other metal parts must go over or around a part...but not sutible for a gear or other guide.
a similar material i've found used on plastic cutting boards. http://www.tapplastics.com/product/plastics/cut_to_size_plastic/hdpe_cutting_boards/346
cut a rectangle out of it and drill a hole through it. Then attach your rod to that. your belt whatnot can attach to the block as well.
