Author Topic: R-91 volume control  (Read 3094 times)
mountaindew
  • Last login:March 13, 2015, 03:29:13 pm
R-91 volume control
« on: October 04, 2012, 10:04:54 am »
When I went to listen to my box today the volume is at the highest and turning the knob changes nothing.Is there any test to do to see what is causing this
Ken Layton
  • Guru
  • Technician
Re: R-91 volume control
« Reply #1 on: October 04, 2012, 10:08:02 am »
Are you using a hardwired remote volume control or the control on the back of the jukebox?
In general, volume wide open indicates a short to ground of the red volume wire.
mountaindew
« Reply #2 on: October 04, 2012, 10:08:47 am »
the volume on the back
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #3 on: October 05, 2012, 08:23:55 am »
Hello Mountaindew,
Unplug the volume control cable at the molex plug on the amplifier. there should be no volume during play.
As Ken says check fo a short on the cable back to the 10k ohm log pot and if there is no short on the cable meter out the pot  on a two wire control the wires will go to one end of the pot and the otherwire will be to the wiper.
You can make up a test contol using another 10k log pot and a molex plug, short pins 1 & 5 together and take a cable to one end of the pot, pin 3 wire up to the wiper.
Regards
Alan
Alan Hood
ami-man
UK
mountaindew
« Reply #4 on: November 19, 2012, 02:37:42 pm »
.Like I said I replaced the volume control component on the back of the juke and still the same.Could the used volume pot be bad
« Last Edit: November 26, 2012, 01:34:14 pm by mountaindew »
mountaindew
« Reply #5 on: January 13, 2013, 03:38:40 pm »
on the volume pot how many wires should be coming from it.I have 2 but it looks like there should be another
Ken Layton
  • Guru
  • Technician
« Reply #6 on: January 13, 2013, 04:56:45 pm »
Just two wires: a red and a black.
mountaindew
« Reply #7 on: January 13, 2013, 05:53:18 pm »
Thank you
