Author Topic: Question about GGG button and iPac  (Read 1743 times)
BrianP
  • Last login:April 25, 2020, 10:03:58 pm
« on: September 28, 2012, 01:59:02 pm »
After about 2 years, I have finally gotten back to working on my cabinet.  I had previously wired the control board using buttons from Groovy Game Gear and an Ultimarc I-Pac2.  Anyway, I installed the Ultmarc WinIPAC Interactive Panel Designer to test the wiring on all the buttons (it had been a while).  Everything looked good except one button.
The player 1 start is activating on a button release, not a button press.  The player 2 start is working fine.  Totally puzzled on this.  Did I wire something wrong?  Or do I have a bad switch?
The switch itself says (best I can tell, white on white is hard to read)
E-Switch LS
15A 125/250 AC
Thanks in advance!
Re: Question about GGG button and iPac
« Reply #1 on: September 28, 2012, 02:02:12 pm »
No, it's fine. That button also serves as a shift button when you hold it down, so it's waiting to see what you do with it before it registers the button push. No stress.
BrianP
« Reply #2 on: September 28, 2012, 04:42:44 pm »
Hmmmm, I tried a game in MameUI and it didn't register, I guess I will have to look at my mame settings.  Thanks.
molton
  • Last login:April 05, 2018, 10:46:57 pm
« Reply #3 on: September 29, 2012, 06:49:30 am »
Use the winIpac application to disable the shift function if you never use it and it will act normally if you want
Smack
  • Last login:May 07, 2013, 11:40:41 pm
  • Who changed my avatar?
« Reply #4 on: September 29, 2012, 09:10:31 am »
Are you wired on the wrong terminals on the switch so it is actually closed all the time and you're breaking the connection when you press the button? Just a thought...
Smack
Never Let Donkey Kong Use Your Toilet.
(We're talkin' big processed brown bananas...)
Somebody out there stole my sig! LOL
  • Last login:Today at 02:24:27 am
« Reply #5 on: September 29, 2012, 10:58:55 pm »
Some games like TMNT used one of the player buttons to start instead of having a separate start button.  Check the "Input (this Game)" menu to verify on your game or just open a notepad window and see if it 'types' a "1" when you hit P1 Start.
ramos8414
  • Last login:January 09, 2019, 08:27:24 pm
« Reply #6 on: July 12, 2013, 01:45:37 am »
Where is the option to disable or change the shift key?
« Last Edit: July 12, 2013, 01:52:05 am by ramos8414 »
« Reply #7 on: July 12, 2013, 01:54:41 am »
Just clear the shifted function slots or program each of them the same as the unshifted function.
