Author Topic: Cabmame 0.146 Soundsync Issue  (Read 4496 times)
Andypc
  • Last login:June 20, 2026, 10:25:14 am
« on: September 23, 2012, 06:26:17 pm »
I just upgraded from Cabmame 0.141 to Cabmame 0.146, but Soundsync seems to be broken as the sound is all over the place in R-Type and Kung Fu Master. I am using the 32bit, Command Line version. Is there a version of 0.146 with Soundsync fixed or will it be fixed for 0.147.
Andypc
Re: Cabmame 0.146 Soundsync Issue
« Reply #1 on: September 24, 2012, 04:07:03 pm »
I just tested the 32bit version of Cabmame 0.146 on a second computer with different hardware and got exactly the same problem with the sound in both R-Type and Kung Fu Master. I tried standard Mame 0.146 and the sound for those games is fine, so there is definately an issue with Soundsync with the 32bit version of Cabmame 0.146. I also tried Cabmame 0.141 and the sound is perfect in those games. I am running Windows XP SP3 32bit. The hardware is completely different on the two computers I tried this on, but I got the same issue.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #2 on: September 25, 2012, 03:38:35 pm »
Use baseline MAME, then. I do when using recent MAME.
-Banned-
Andypc
« Reply #3 on: September 25, 2012, 03:52:11 pm »
Unfortunately some games need the Soundsync otherwise they stutter with base mame. i.e. Pacland.
Andypc
« Reply #4 on: September 27, 2012, 05:01:51 pm »
MAMEUIFX 0.147 32bit  has exactly the same issue with Soundsync. I have tested this on both computers with Windows XP 32bit SP3.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: September 28, 2012, 05:52:41 am »
Caan't help ya. No issue on my machines with XP 32.
-Banned-
Andypc
« Reply #6 on: September 29, 2012, 04:49:06 am »
Please see the thread below on the Soundsync issue
http://www.phpbbserver.com/mameuifx/viewtopic.php?t=430&mforum=mameuifx
Andypc
« Reply #7 on: October 19, 2012, 03:52:02 pm »
Does anyone know if it is possible to disable "Soundsync" in the .ini file for Cabmame? As that would solve the problem as I could enable it for game that need it and disable it on games that it causes problems with.
« Last Edit: October 19, 2012, 04:39:30 pm by Andypc »
brown
  • Newbie
  • Last login:August 16, 2014, 02:16:34 am
« Reply #8 on: October 23, 2012, 03:15:52 am »
good comments.......................
