Author Topic: Nestopia Controller Compatibility  (Read 4457 times)
wileymiester
  • Last login:February 19, 2013, 09:47:32 am
« on: September 18, 2012, 09:43:53 am »
I've put together a computer running windows 7 (64b it) and connected it to my TV so that I can turn on an emulator and play it on the couch.  I have a xbox 360 controller that I'm using with nestopia that seems to be working properly.  However, I also have a tigergames ps/2 usb adaptor that I'd like to use instead but for some reason its like every button is running with autofire.  So if I hold down the left D-pad button the my character on the screen moves as if i'm rapidly tapping the left D-pad button rather than holding it down.  I'm not sure what I can do to correct the problem.  I've tried running nestopia in XP compatibility mode but I'm still running into the same problem.
Any suggestions?
northerngames
  • Trade Count: (+18)
Re: Nestopia Controller Compatibility
« Reply #1 on: September 18, 2012, 01:23:01 pm »
could be hardware or software.
like a setting or perhaps a cracked ground wire or something.
may be the adapter itself though as I never heard of it and am not a fan of 3rd party anything becuase most dont work right outta the box.
« Reply #2 on: September 18, 2012, 02:02:12 pm »
See if that is the way windows is reading the input. In Win 7, go do your devices + printers in the start menu. Then find where the gamepad device shows up and right click and go to settings. click on your device and it will bring up a diagram of what you push. see if pushing left shows as a constant press or going on and off repeatedly.
If it shows a constant press as normal, I would switch to FCE Ultra as my NES emulator, see if that works without problems.
wileymiester
« Reply #3 on: September 18, 2012, 02:13:28 pm »
Thanks Vigo.  I used your method to help troubleshoot the problem and it looks like the controller i was using was the culprit.  Its working fine now.
Thanks again!
