Author Topic: Wallbox for a Rowe R-86  (Read 5507 times)
rpucci
  • Last login:November 03, 2014, 07:00:48 pm
« on: September 01, 2012, 12:13:45 pm »
Hi  Can someone tell me what wallbox I need for a Rowe R-86 and what else like an interface,power supply etc.Thanks
Bob
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Wallbox for a Rowe R-86
« Reply #1 on: September 03, 2012, 05:35:41 am »
Hi Bob,
You could use the WRD or WRE Wallette wall box if you were in the UK you could also use the Hazel Grove Music Playmate or the MHG (Kunick) Panoramic wall box.
Regards
Alan
Alan Hood
ami-man
UK
rpucci
« Reply #2 on: September 03, 2012, 07:37:44 am »
Hi Alan
Thanks for your reply.I'm in the states and you helped me once with my gripper bow.Does that mean I will have to get WRE or a WRD box here?Thanks
Regards
Bob
ami-man
« Reply #3 on: September 04, 2012, 06:12:41 am »
Hi Bob,
Yes I remember you Bob.
You will have to look for the WRD or WRE wallbox or you could use one of the earlier WRA or WRC with the correct interface (6-07467-02) you can tell if is the correct interface because the connections will be as follows:-
AC
AC Common
AC Contol
Signal
The interface converts the signal to a digital pulse.
Regards
Alan
Alan Hood
ami-man
UK
rpucci
« Reply #4 on: September 04, 2012, 06:36:57 pm »
Hi Alan
Thanks for your reply.If I get a WRD or a WRE wallbox,is that all I need or will I need a separate power supply for it,an interface and cables to mount it somewhere.
I hope I explained it right.
Bob
ami-man
« Reply #5 on: September 05, 2012, 06:22:52 am »
Hi Bob,
You will need a wallbox transformer (best bet is to get the Rowe Ami one there is usually a number on Ebay)
the interface and cables to the location of the wallbox. You need larger cables for the AC to the wallbox so you do not get any voltage drop.
Regards
Alan
Alan Hood
ami-man
UK
rpucci
« Reply #6 on: September 12, 2012, 06:40:44 pm »
Hi Alan
Received my WRD wallbox today.Do you know where I can get a service manual for it?
Also where can I get a correct interface.That's why I need the manual,I'm not too smart
in hooking up things.thanks
The titled cards don't turn.It has a screw missing.I got it off ebay and took a chance.
Regards
Bob
« Last Edit: September 12, 2012, 07:36:21 pm by rpucci »
ami-man
« Reply #7 on: September 19, 2012, 10:50:30 am »
Hi Bob,
Send me a picture and I will see if I have got anything that will sort out the problem.
Regards
Alan
Alan Hood
ami-man
UK
rpucci
« Reply #8 on: September 19, 2012, 01:21:44 pm »
Hi Alan
I now have the manual and I fixed the problem with the title turnstile.
What kind of pictures do you want.I'll send outside and inside later on today.
Bob
xmaffox
  • Last login:December 09, 2014, 12:51:33 pm
« Reply #9 on: December 09, 2014, 12:24:56 pm »
Hello Guys! I'm Simone from Italy! I am desperately looking for an instruction manual of Rowe Ami WRD consolette. Is there anyone of you that could send the scanned version to me upon payent?
