Author Topic: Wells Gardner 19k7602 Screen Issue  (Read 5214 times)
JoJoRockets52
  • Last login:August 26, 2012, 12:20:38 am
« on: August 18, 2012, 10:57:10 pm »
I am currently trying to hook up my Dreamcast to my Arcade Monitor. Saddly when it comes to arcade monitors I have very little experience if any at all. So I read some tutorials online about how to connect the Dreamcast through the VGA box using the 15khz "hack". I then wired up the monitor with a VGA cable which I stripped and installed it directly onto the RGB/Ground/Sync. I ended up getting an image that turned out like this
 Any idea's?
ed12
Re: Wells Gardner 19k7602 Screen Issue
« Reply #1 on: August 18, 2012, 11:30:47 pm »
hi
ya your missing 1/2 of your sync pulse
ed
JoJoRockets52
« Reply #2 on: August 18, 2012, 11:32:44 pm »
What is the Sync pulse. Does that mean I'm missing either my vertical sync or horizontal sync. I really have no idea.
ed12
« Reply #3 on: August 19, 2012, 01:06:09 am »
hi
yes
sync is just that
u have to fiquire that part out
or post a pic. of the chassic
i will walk u through it
ed
JoJoRockets52
« Reply #4 on: August 19, 2012, 01:21:53 am »
I read online that you were supposed to twist the H-sync and V-sync together (coming off the VGA box) I spliced it with the grey wire coming off the monitor here . I then attached the ground to the black wire (from the VGA). Then Red to Red/Blue to Blue/Green to Green. I think the colors are good its just that weird distortion.
ed12
« Reply #5 on: August 19, 2012, 11:38:12 am »
hi
red/green/blue/black miss 1 sync/sync
ed
JoJoRockets52
« Reply #6 on: August 19, 2012, 01:18:37 pm »
hi
ed
So there are supposed to be two wires for the sync (horizontal/vertical)? Would that mean I am missing a ground wire? I really have no idea. I read that the k7000 series used composite sync on the negative H-sync. If so were would that be?
Again I'm sorry for being ignorant.
EDIT
I think I see what you are saying. So it looks like I'm missing a ground wire. Which would be pin 4.
Then I would wire vertical and horizontal to pins 5 and 6, but they are wired on a different looking harness. Would I need to add them to the 6 pin harness along with another ground wire?
How would I go about adding another wire to the harness?
« Last Edit: August 19, 2012, 01:38:53 pm by JoJoRockets52 »
ed12
« Reply #7 on: August 19, 2012, 02:55:45 pm »
hi
yes
red/green/blue/ground / sync/sync  on the next 3 pin plug ground.sync/sync
u need to pick + sync or - sync
ed
JoJoRockets52
« Reply #8 on: August 19, 2012, 04:16:41 pm »
Would it be best to just buy a new 6 pin harness, or is there an easy way to attach the 3 missing pins?
ed12
« Reply #9 on: August 19, 2012, 04:44:19 pm »
hi
most just solder to the pin's
i have done it countless time's before
ed
JoJoRockets52
« Reply #10 on: August 20, 2012, 01:52:06 pm »
I need to run to Radio Shack and grab some more wire and will try again tonight. On another forum someone suggested wiring to the Neg V/H sync. Since the dreamcast outputs positive sync should I wire positive to positive or negative to negative?
JoJoRockets52
« Reply #11 on: August 24, 2012, 02:07:04 pm »
Well I decided to just order a new harness online. I wired red/green/blue/ground/Vsync/Hsync and I no longer get any picture.  :banghead: Any Ideas?
ed12
« Reply #12 on: August 24, 2012, 02:47:15 pm »
hi
either use + sync or - sync
but never both
also a fast test is to remove the sync line's
and see what happen's
pic should be there but rolling vert,and have horz line's
ie the screen is light but u cannot get it to sync
that tell's u u are on the right track
ed
JoJoRockets52
« Reply #13 on: August 24, 2012, 04:05:31 pm »
I have the syncs wired to the positive spots. I doesn't look like I am even getting an image even with the syncs completely off.
grantspain
« Reply #14 on: August 24, 2012, 08:36:12 pm »
could be wrong but i thought dreamcast to 15khz monitor requires a sync splitter
JoJoRockets52
« Reply #15 on: August 24, 2012, 11:51:36 pm »
It has a horizontal/vertical sync. Though I'm not exactly sure what the sync splitter is.
grantspain
JoJoRockets52
« Reply #17 on: August 26, 2012, 12:13:45 am »
I know but when I connected it i could not get an image (red/blue/green/gnd/vsync/hsync) I did get an image like my first post when I had V/H sync tied together onto the negative h sync.
